How Far Does a Projectile Travel When Fired from a Cliff?
  • Thread starter Thread starter roe
The problem involves a projectile being fired from a cliff 60.0 m high at a speed of 100 m/s and an angle of 35.0 degrees below the horizontal. The objective is to determine the horizontal distance from the base of the cliff to the point where the projectile impacts the water.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the need to calculate the time of flight to determine the horizontal distance. There are attempts to break down the problem using trigonometric functions to find initial velocity components. Some participants express confusion about setting up the equations correctly and question the relevance of time in their calculations.
There are various approaches being explored, with some participants suggesting different methods to find the time of flight and others focusing on the use of trigonometry. Guidance has been offered regarding the initial vertical velocity and the setup of equations, but no consensus has been reached on the best approach.
Participants are navigating the complexities of projectile motion, including the effects of angle and initial velocity. There is mention of confusion regarding the setup of the problem, particularly in transitioning from one-dimensional to two-dimensional motion.
roe
<b>Q:</b>A projectile is shot from the edge of a vertical cliff 60.0 m above the ocean. It has a speed of 100 m/s and is fired at an angle of 35.0 degrees below the horizon. How far from the foot of the vertical cliff does the projectile hit the water?
My take on the problem:
Code:
          __________
          |\ ) 35 degree angle
          |______\
  ^          ^ what I'm trying to find (xf)
60m
So what I'm trying to do is figure out how far this projectile will go in the +x direction before it reaches the bottom of the cliff (60 m).
My problem is that I'm getting quite confused as to how to start solving this problem. Please help me get started!
The first thing you want to find is how long it takes to hit the ground. From there you'll be able to find everything else. Don't forget that it has an initial vertical velocity..
Hi Roe,
I would start with getting the inside angle, so 90-35. That gives you two angles and one side (60M).
OK, I'm not seeing how to determine when it hits the ground. I've been doing 1-dimensional problems for the last couple of hours but I'm really not understanding how to set this problem up. What I have so far is:
Vxi = (100 m/s) cos 55 degrees = 57.36 m/s
Vyi = (100 m/s) sin 55 degrees = 81.92 m/s
yf = yi +vyi(t) + .5(ay)(t^2)
with yi = 0, yf = -60m, ay = -g, Vyi = 81.92 m/s
so...
-60m = (81.92m/s)(t) - .5(-9.8m/s/s)(t^2)
And then I'd solve the quadratic equation for t.
Am I on the right track with this?
