Solving the Puzzle: Acceleration of a 50kg Block
The problem involves calculating the acceleration of a 50kg block sliding on a horizontal surface with a coefficient of kinetic friction (uk) of 0.60, under the influence of a 400 N force applied at a 20° angle. The correct approach requires adjusting the normal force (N) to account for the vertical component of the applied force. The equation to determine acceleration (a) is given by 400N*Cos(20) - [(9.81 m/s²)(50kg) - (400)(sin(20))](0.60) = (50kg)(a). This results in an acceleration of approximately 2.31 m/s², aligning with one of the provided answer choices.
  • Understanding of Newton's laws of motion
  • Knowledge of frictional forces and coefficients
  • Ability to resolve forces into components
  • Familiarity with basic kinematic equations
  • Study the concept of normal force in inclined scenarios
  • Learn about the effects of angle on force components
  • Explore frictional force calculations in different contexts
  • Practice problems involving multiple forces acting on an object
Students studying physics, particularly those focusing on mechanics, as well as educators looking for examples of force and motion problems.
phizuks
I'm not sure why I'm not getting this problem right. It seems pretty simple to me, but I guess there might be a trick to it?
Suppose that a 50kg block slides along a horizontal surface where the coefficient of kinetic friction between the block and the surface is uk = 0.60. A force F = 400 N is now applied as shown in the drawing, where the angle of the force above horizontal is 20°.
What is the magnitude of the acceleration of the block?
Isn't the equation just 400N*Cos(20)-(9.81 m/s^2)(50kg)(.60) = (50kg)(a)
I get a = 1.63 m/s^2
The choices the online homework gives are
.54, 2.31, 3.27 (2x the accel i get), 6.78, and 8.11
You need to take into account the increased N, as it now has to deal with both gravity and the y-component of the F. This, of course, increases the force caused by friction.
the normal reaction here will be less than 50*9.8...bcoz the force F has a component in the vertical dir.
N=50*9.8 - 400*sin(20)
so ur eqn shud actually b
400N*Cos(20)-[(9.81 m/s^2)(50kg)-(400)(sin(20))](.60) = (50kg)(a)
i think u shud get the ans frm this.
bye
  • · Replies 33 ·
9K
