A jet transport has a weight of 2.97 x 106 N and is at rest on the runway
The discussion revolves around two physics problems: the first involves a jet transport's weight distribution and forces on its wheels, while the second concerns the net torque acting on a CD as it accelerates. Both problems fall under the subject areas of mechanics and rotational dynamics.
  • Mixed
  • Participants explore equilibrium conditions for the jet transport, discussing the forces on the front and rear wheels and the use of torque equations. For the CD problem, there are attempts to calculate moment of inertia and angular acceleration, with some participants expressing confusion about the steps involved.
Some participants have provided guidance on setting up equations for the first problem, while others are working through calculations for the second problem. There is an ongoing exchange of ideas, with participants questioning their assumptions and clarifying their approaches.
Participants note the importance of using consistent units in calculations, particularly when transitioning between grams and kilograms or centimeters and meters. There is also mention of imposed homework rules regarding the level of detail allowed in responses.
moonlit
I have two problems for homework that I just can't seem to figure out. Can someone please help me?! Thanks.
1) A jet transport has a weight of 2.97 x 106 N and is at rest on the runway. The two rear wheels are 17 m behind the front wheel, and the plane's center of gravity is 13.1 m behind the front wheel. Determine the normal force exerted by the ground on (a) the front wheel and on (b) each of the two rear wheels.
2) A CD has a mass of 17 g and a radius of 6 cm. When inserted into a player, the CD starts from rest and accelerates to an angular velocity of 18 rad/s in 0.53 s. Assuming the CD is a uniform solid disk, determine the net torque acting on it.
1. The plane is in equilibrium. Sum the forces in the y-direction and the moments about a point and set both sums equal to zero. Hint: the 2 rear wheels see the same reaction force from the ground (you could show that explicitly by a separate moment balance in that plane (geometric plane, not airplane)).
2. Calculate the moment of inertia of the disk about its center. Determine the angular acceleration using the kinematic data given. Then use the fact that [itex]\vec{\tau}_{\rm net} = I\vec{\alpha}[/itex]
For the first problem, it should be obvious, from symmetry, that the force on the two rear wheels must be the same (if it is not obvious, or you are not allowed to say that, look at the problem from side to side to get a third equation).
Let F1 be the weight (force) on the front wheel, F2 the weight on each rear wheel. The total forces must equal the weight of the entire airplane: F1+ 2F2= 2.97 x 106 (I read "2.97 x 106 N" but I assume that was supposed to be "106). The torques about the center of gravity are 1.31F1 for the front wheel and (3.9)(2F2)for the rear wheels and they must be equal. That gives you two equations in two unknowns to solve for F1 and F2.
(If you are not allowed to say that the forces on the rear wheels are "obviously" the same, set up three equations: F1+ F2+ F3= 2.97 x 106 (F2 and F3 are the forces on the two rear wheels), 1.31 F1= 3.9F2+ 3.9F3 and w F2= wF3 where w is the distance from the center line to each of the two rear wheels. "Obviously", that last equation gives F2= F3 and then you are back to the first set of equations.
In straight line motion, we have "F= ma". In rotary motion, we have "F= I a" where I is the "moment of inertia" of the disk. If you are expected to do this problem, you should know a formula for the moment of inertia of a uniform solid disk.
Ok. I'm still having problems getting the second problem. I know that T=mr^2 and the net torque = the moment of inertia x angular acceleration but I still don't get it. I've tried 17 x 6^2 = 10404 but I'm not sure where to go from there for if that's even correct. Can someone show me some of the steps or something so I can understand it better? Thanks.
First calculate the moment of inertia for a disk:
I = 1/2MR2
Then find the angular acceleration:
α = Δω/Δt
Then you can find the net torque that is producing the acceleration:
Τ = I α
Take care to use correct units!
I must be doing something wrong. Here's what I've come up with so far:
I=1/2MR^2
1/2(17x6^2)=306
á = Äù/Ät
18/.53=33.96
Ô = I á
306 x 33.96=10391.76
I=1/2MR^2
1/2(17x6^2)=306
You are doing fine, just be careful to use a consistent system of units. For example:
M = 0.017 kg
R = 0.06 meters
There is nothing wrong with the units you used, if you are aware of what you are doing. You used grams and centimeters; your answer for I is in gm-cm2. Unless you meant to use those units, I would advise you to stick to the usual SI units. (But do whatever your instructor does!)
Ok I got the answer of 10.39x10^-4 NxM. Thanks for all your help!
9K
18K
