Two Differential Equation Problems
The discussion focuses on solving two differential equation problems involving the characteristic polynomial of the form y'' + a_1y' + a_2y = 0, where a_1 and a_2 are real constants. Key points include demonstrating that if α + iβ is a root, then α - iβ is also a root, and expressing the general solution as φ(x) = e^(αx)(d_1cos(βx) + d_2sin(βx)). Additionally, it is established that α = -a_1/2 and β² = a_2 - (a_1²/4), with solutions tending to zero as x approaches infinity if a_1 > 0, and diverging if a_1 < 0. The second problem confirms that solutions tend to zero as x approaches infinity if the real parts of the roots are negative.
  • Understanding of characteristic polynomials in differential equations
  • Familiarity with complex numbers and their properties
  • Knowledge of general solutions for second-order linear homogeneous differential equations
  • Ability to analyze limits and behavior of functions as x approaches infinity
  • Study the derivation of the characteristic polynomial for second-order differential equations
  • Learn about the implications of complex roots in differential equations
  • Explore the method of undetermined coefficients for solving linear differential equations
  • Investigate the behavior of solutions to differential equations at infinity
Students and professionals in mathematics, particularly those focusing on differential equations, engineers dealing with dynamic systems, and anyone interested in the stability analysis of solutions.
JM00404
Problem I.
Consider the equation
[tex]y''+a_1y'+a_2y=0[/tex]
where the constants [tex]a_1,a_2[/tex] are real. Suppose [tex]\alpha+i\beta[/tex] is a complex root of the
characteristic polynomial, where [tex]\alpha,\beta[/tex] are real, [tex]\beta\neq 0[/tex] .
(i) Show that [tex]\alpha-i\beta[/tex] is also a root.
(ii) Show that any solution [tex]\phi[/tex] may be written in the form
[tex]\phi(x)=e^{\alpha x}(d_1\cos(\beta x)+d_2\sin(\beta x))[/tex] ,
where [tex]d_1,d_2[/tex] are constants.
(iii) Show the [tex]\alpha=-a_1/2, \beta^2=a_2-(a_1^2/4)[/tex] .
(iv) Show that every solution tends to zero as [tex]x\rightarrow +\infty[/tex] if [tex]a_1>0[/tex] .
(v) Show that the magnitude of every non-trivial solution assumes aribtrarily large values as [tex]x\rightarrow +\infty[/tex] if [tex]a_1<0[/tex] .
Problem II.
Show that every solution of the constant coefficient equation
tends to zero as [tex]x\rightarrow \infty[/tex] if, and only if, the real parts of the roots of the characteristic polynomial are negative.
I cannot seem to solve parts (iii) through (v) in problem I and the whole of problem II correctly. I am really not all that sure where I should begin on these parts. Any assistance offered would be much appreciated. Thank you for your time.
JM00404 said:
Problem I.
Problem II.
For part (iii) of problem 1, have you tried to solve the auxillary equation with the arbitrary a1 and a2?
Part (iv): Look at your general solutions to the differential equation and notice what happens when you plug in "infinity" for x.
Problem 2: Solve the auxillary equation and split it into the three cases that you should know for linear, homogenous, 2nd order differential equations. Then show that only the complex root case will give you the infinity.
I agree with what TimNguyen said above.
Give you another hint for question 2.
What's the value of [tex]|e^{i\beta x}|[/tex]? and then what's the value of [tex]\lim_{x\rightarrow\infty}e^{-\lambda^2 x}[/tex]?
  • · Replies 29 ·
  • · Replies 20 ·
