Relativity question for Hard SciFi writing
The discussion revolves around the implications of relativistic collisions in the context of hard science fiction writing. Participants explore the effects of an asteroid traveling at velocities exceeding the speed of light upon colliding with a slower-moving planet, focusing on the theoretical consequences and the nature of momentum and energy transfer in such scenarios.
  • Exploratory, Conceptual clarification, Debate/contested
  • One participant questions the nature of a collision involving an asteroid traveling at relativistic speeds, particularly at or above the speed of light, and seeks to understand the potential damage caused.
  • Another participant suggests that such a collision would be "wholly imaginary," implying that the physics of superluminal speeds leads to nonsensical results.
  • A further elaboration indicates that using velocities like 5c or 10c results in imaginary quantities when calculating momentum transfer, raising the question of how to quantify "imaginary damage."
  • Some participants propose that for a more scientifically grounded narrative, the asteroid's speed should be limited to 0.9c, allowing for meaningful quantitative and qualitative analysis.
  • One participant suggests considering a more fantastical approach to the narrative, emphasizing the creative freedom in science fiction while also encouraging an understanding of real-world physics for contrast.
Participants express differing views on the feasibility of superluminal collisions, with some asserting that such scenarios lead to nonsensical outcomes while others advocate for a more grounded approach in writing. No consensus is reached on the implications of these hypothetical collisions.
The discussion highlights limitations in applying real-world physics to scenarios involving superluminal speeds, particularly concerning the mathematical treatment of momentum and energy transfer. The implications of imaginary quantities in physics are also noted but remain unresolved.
hellebyuck
I'm working on writing some hard science fiction stuff, and I have a question I was hoping you guys could help me with. See, my training is primarily in math and chemistry, and it's been quite some time since I've really had any dealings with more than just the most basic concepts in general relativity.
So here's my problem. Not worrying about the means of getting to these speeds, you have a large, massive object, say, an asteroid, traveling at relativistic velocities, colliding with something comparitively slow moving, like a planet. I know that as the velocity moves into larger fractions of c the momentum will increase geometrically, as both mass and velocity increase. Greater momentum means greater energy transferred upon collision, et cetera. That much is easy. What I'm wondering is, if that object is moving at or above the velocity of light (again, don't worry about how it gets moving that fast. just assume constant velocity until the moment of impact), what would happen on collision? How would an asteroid traveling at ten times c compare to one traveling at, say, five hundred times c in terms of relative damage?
Thanks in advance.
It would be a wholly imaginary collision, in many senses of the word..
To elaborate a bit...
The amount of damage caused by a collision can be measured by the 4-momentum transfer from one object to another. This is a measure of the violence of the collision. But if you put velocities of 5c and 10c into the equations, you get imaginary quantities. How do you measure imaginary damage?
If you want to write a book with which trained physicists can help you, then it would be better if your asteroid were moving at 0.9c. Then we can give you some quantitative and qualitative information.
Alternatively, you might consider a playful fantasy-scifi novel set in a universe rather different than ours (art should, after all, be a free conception of the mind, to subvert a well-known quote from a well-knowner physicist).
But, also in this case, I would think it advantageous for you to learn what actually happens in our universe, in order to make a nice contrast to the developments in your own world.
Many PF'ers would be happy to provide info on our universe, but don't be too sure they will help you develop your own version.
They might buy the book, though, if turns out good..:wink:
  • · Replies 96 ·
13K
  • · Replies 32 ·
