Finding Steady State Solutions for a Mass-Spring System with a Moving Support
The discussion focuses on finding steady state solutions for a mass-spring system described by the differential equation \(\frac{{d^2 x}}{{dt^2 }} + 2p\frac{{dx}}{{dt}} + \omega _0 ^2 x = 2\sin(t)\). For \(w_0 = 3\) and \(p = 1\), the steady state solution is identified as \(x_p(t) = \frac{1}{5}(4\sin t - \cos t)\). Additionally, it is concluded that for \(p = 0\), the system exhibits no steady state when \(w_0 = 1\), as the roots of the auxiliary equation become double roots, leading to unbounded oscillations.
  • Understanding of differential equations, specifically second-order linear equations.
  • Familiarity with concepts of steady state solutions and particular solutions.
  • Knowledge of resonance phenomena in oscillatory systems.
  • Ability to compute derivatives and integrals related to motion and oscillation.
  • Study the derivation of particular solutions for non-homogeneous differential equations.
  • Explore the concept of resonance in mechanical systems and its implications.
  • Learn about the method of undetermined coefficients for solving differential equations.
  • Investigate the effects of damping on oscillatory systems and how it alters steady state behavior.
Students and professionals in physics and engineering, particularly those focusing on dynamics, control systems, and mechanical vibrations.
Benny
Can someone help me out with the following question?
Q. The position x(t) at time t of a mass attached to a spring hanging from a moving support satisifies the differential equation:
[tex] \frac{{d^2 x}}{{dt^2 }} + 2p\frac{{dx}}{{dt}} + \omega _0 ^2 x = 2\sin \left( t \right)[/tex]
a) Find the steady state solution when w_0 = 3 and p = 1.
b) If p = 0 then there is a value for w_0 > 0 for which there is no steady state. What is this value of w_0? Justify your answer by finding the particular solution.
a) The auxillary equation has complex roots with a negative real part so the complimentary function isn't a part of the steady state solution since the decaying exponential leads to the complimentary function tending to zero as t gets large? So I need a particular solution I think. I found [tex]x_p \left( t \right) = \frac{1}{5}\left( {4\sin t - \cos t} \right)[/tex].
b) I'm not really sure about this part but I found a particular solution anyway. I obtained [tex]x_p \left( t \right) = \frac{{2\sin \left( t \right)}}{{\omega _0 ^2 - 1}}[/tex]. I don't understand what is meant by find a value for which there is no steady state. w_0 is constant so x_p(t) is just sine function with the 'usual' behaviour isn't it? If I were to guess I'd just say w_0 = 1 but could someone help me out with this question?
I would also like to know if the following would be a 'valid' way to quickly formulate the formula for the surface area of a graph revolved about the x-axis.
A bit of arc length is [tex]dL = \sqrt {1 + \left( {\frac{{dy}}{{dx}}} \right)^2 } dx[/tex]. A 'sample' circumference is [tex]dC = 2\pi (height) = 2\pi f\left( x \right)[/tex]. Then the surface area of the graph revolved about the x-axis from x = a to x = b is [tex]S = \int\limits_a^b {2\pi f\left( x \right)} \sqrt {1 + \left( {\frac{{dy}}{{dx}}} \right)^2 } dx[/tex]?
Well Benny, this involves resonance right? What happens when [itex]\omega=1[/itex] in the differential equation with no damping? We get:
[tex]x^{''}+x=2Sin(t)[/tex]
But in that case, both the roots of the auxilliary equation and the roots of the differential operator for which the RHS is a particular solution are [itex]\pm i[/itex]? That means we have double roots. That means the particular solution is actually of the form:
[tex]y_p(x)=AtSin(t)+BtCos(t)[/tex]
So, the t in front of them means it oscillates without bounds right? That happens whenever input frequenies match output frequencies.
Thanks for the help Saltydog.
  • · Replies 30 ·
