A little critique on magnetic lines of force.
  • Context: Graduate
  • Thread starter Thread starter Fairfield
    Force Lines Magnetic
The discussion critiques the conventional understanding of magnetic lines of force, particularly in relation to direct current (DC) and magnetic compass needles. It asserts that genuine magnetism requires at least two opposing currents, which a straight current does not provide, leading to the misapplication of the term "magnetic lines of force." The author proposes alternative terminology, such as "Oersted's north-south lines OF NO FORCE" and "Ampereism," to clarify the distinction between true magnetism and the effects observed around current-carrying wires. This redefinition aims to eliminate confusion in scientific discourse regarding magnetism and electricity.
  • Understanding of basic electromagnetism principles
  • Familiarity with direct current (DC) circuits
  • Knowledge of magnetic fields and forces
  • Concept of inductive fields and their properties
  • Research "Ampere's Law and its applications" to understand the relationship between current and magnetic fields.
  • Explore "Faraday's Law of Induction" to grasp the principles of electromagnetic induction.
  • Study "Lorentz Force" to comprehend the interactions between magnetic fields and moving charges.
  • Investigate "Oersted's Experiment" to see the historical context of magnetism related to electric currents.
Physicists, electrical engineers, educators, and students interested in clarifying concepts of magnetism and electromagnetism, as well as those seeking to enhance their understanding of the relationship between electricity and magnetism.
Fairfield
In studying magnetism, and magnetic lines of force, it seems clear to me that a problem arises from misconstruing what a magnetic compass needle is really doing when it is placed near a straight direct current. The name magnetism was originally applied to certain objects (including magnetic compass needles) which could display polarized MUTUAL attraction, or repulsion, with a measurable FORCE. Therefore, using sound semantics, you can't have real magnetic lines of force without two such objects. Therefore, to apply this name to something which supposedly encircles a current carrying wire, but doesn't have two objects along the alleged lines of force to refer this alleged force to, redefines the meaning of the phrase "magnetic lines of force" in midstream. This redefinition follows from falsely assuming that any active magnetic compass needle indication always refers to magnetic lines of force. This is definitely not the case.
To explain this inadvertent switch in the meaning of the phrase, "magnetic lines of force", when it is applied to the area around a straight wire current, we have to consider what the true definition of magnetism originally referred to, and therefore, should continue to refer to, unless formally redefined.. The term "magnetism" was originally applied to types of objects which, unknown to everybody at the time, contain multiple looped micro electric currents for there particular force manifestation, which, therefore, have, spatially speaking, no less than two opposing parallel currents in them (opposite edges of a loop or coil, or the electrically equivalent situation in magnets). Since a straight wired current in no way has either a loop, or two opposing currents, it does not qualify as a magnetic object which can generate genuine magnetic lines of force. But it does generate radial Ampereic lines of force. See below.
The situation of a magnetic compass needle near a straight current is a different kind of relationship (easily explained below) than between two genuine magnetic objects (of which the magnetic compass needle can be one of them). The compass needle therefore, near a straight current, falsely projects, in one's imagination, something to which the original meaning of the phrase, "magnetic lines of force", does not apply.
To have a name kicking around in science which has two different meanings is not a helpful thing in my opinion. If the incorrect name, "magnetic lines of force", for this particular situation (magnetic compass indication near a straight current) has been incorporated into so many physics formulas that it can't be extricated, or if it is used in a monitoring/calculating reference system, then I suggest that, at least, the name of the indicated lines be changed to "Oersted's north-south lines OF NO FORCE", or to "pseudo magnetic lines".
It would be even better, but a mouthful, to call these compass indicated "north-south" lines around a straight current, "Oersted's right angled offset current direction indicators", because they are simply derived from the physioelectric response of a loop current (or its equivalent in a magnetic compass needle) near a straight current, depending on the straight current's direction. This kind of physioelectric effect between current carrying wires, whether there is a passive pivotal loop current device involved or not, should properly be called Ampereism, not magnetism (see below).
The paragraphs following this one are based on the premise that two single turn DC carrying coils placed near to each other, and on the same axis, are merely two rolled up parallel wires which will attract or repel each other depending on whether their parallel currents are in the same or opposite parallel directions. To elaborate a little, if two single turn DC carrying coils are each formed into a square, and the two squares are placed near to each other on the same axis, it will be seen that, in this case, there are 8 parallel wires altogether (16 if oppisite sides are counted), 4 on each square coil. Although within each square coil all the parallel wires will repel each other because of their spatially opposite parallel currents, between the two squares there may be either attraction or repulsion, depending on whether their parallel currents are in the same direction or the opposing direction. Since merely flipping the face of one of the squares, 180 degrees, automatically reverses the current, the previous physical attraction or repulsion between the two squares will then also be reversed.
Since the working force between the two squared coils is obviously the effects of close parallel currents rather than a mysterious force called magnetism, which apparent force is really only a vector resultant of the forces between the shared parallel multiple sections of the two coils, I, therefore, believe this net attractive or repulsive force between DC carrying coils should be called "multiple ampereism", rather than magnetism, in honor of the person who first discovered these physical actions between close parallel current carrying wires. The term "magnetism", I think, is best considered as a nick name. Since physical magnets show the same physical reactions between them as DC carrying coils show, I assume a similar process is at work between magnets, but relying on the net effect of many separate micro electric currents within the magnets rather than on easily locatable electric currents in wires.
Further, by careful definition, you also can't have "lines of magnetic force" encircling the individual wires of a direct current carrying coil, because you only get genuine "magnetism" off the faces of a loop, or off the ends of a tubular coil, or off the ends of a magnet, (or magnetic compass needle) as a MUTUAL VECTOR RESULTANT FORCE between at least two pairs of parallel currents (at least 4 parallel currents altogether), at least one pair in each magnetic entity, when they are brought near to each other. This mutual vector resultant force varies with different orientations between any two magnetic entities. However, encircling the individual internal wires of a coil, you only have pseudo magnetic lines. These lines of no force, naturally, cannot
be added up to create a net magnetic force. However, there are radial lines of Ampereic attractive force around each wire which must be added up altogether. But proper semantics demands that this radial force around each wire of a current carrying loop, or coil, should NOT be called magnetic force.
Since genuine magnetism, according to the original definition, requires at least two parallel opposing currents in each coil, or the electrical equivalent in magnets, it is clear that magnetism and electromagnetism is a more complex arrangement of a more simple force system relating to the physical reactions between close parallel currents. Since it was Andre M. Ampere who first discovered this physical reaction between close parallel currents, it would seem only proper to call this more primary system, Ampereism, and the forces operating there, Ampere's radial lines of physical force.
From the above considerations, it appears to me that the overall problem of properly relating magnetism to electricity is that magnetism is a compound forces relation system built up of a lower order forces relation system, which latter system should properly be called Ampereism. Therefore, magnetism provides only a confusing view of Ampereism.
What both the loop currents and the straight currents do have in common is they both have inductive fields which the working physicist and electrical engineer need to keep track of in order to get a mathematical hold on either field's electrical and physical effects. But it is not helpful to drag around confusing names. A straight wire current's inductive field is just that. It is not a loop current's inductive field, so it should not be called a magnetic inductive field. On the other hand, spatially speaking, a magnetic inductive field is a combination of at least two sub inductive fields. If a common name is going to be used for both types of inductive fields, and the lines for their flux densities, it should obviously be "Faradayic flux density" instead of, "magnetic flux density".
Also, referencing Ampereic lines of force, instead of magnetic lines of force, makes it easier to explain the physical reactive motions of current carrying wires in relation to magnetic fields. For instance, the Lorentz Force resolves into the, less mysterious, current carrying wire being attracted toward the side of a current carrying coil which has the same direction current as the movable current carrying wire The same applies to currents in cathode ray tubes when they are manipulated with varying currents in coils. The Hall Effect is easily explained in a similar way.
Finally, if there can't be real magnetic lines of force around single straight current carrying wires, then it follows that there can't be real magnetic waves in electromagnetic waves. Instead, the secondary wave component must necessarily be described as a radially moving, longitudinally alternating, wave of inductive force.
Contrary opinions welcome at the Physics Forums link above.
Fairfield
Can't find the Edit Button. The last paragraph reads better as: Finally, if there can't be real (mutual) magnetic lines of force encircling single straight current carrying wires, then it follows that there can't be real transverse magnetic waves in electromagnetic waves. Instead, the accompanying wave component must necessarily be described as a radially moving, longitudinally alternating, wave of inductive force.
  • · Replies 27 ·
  • · Replies 60 ·
