Finding T in an Elevator Moving with Constant Velocity
The discussion revolves around a physics problem involving an elevator with a mass of 1200 kg that is accelerating upward and later moving at a constant velocity. Participants are tasked with finding the tension in the cable (T) during these scenarios.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the application of Newton's second law (F=ma) to find the tension in the cable, questioning how to account for acceleration and velocity in the calculations. Some participants clarify the relationship between tension, weight, and net force, while others emphasize the importance of understanding the implications of constant velocity on acceleration.
The discussion is active, with participants providing guidance on the correct application of forces and clarifying misconceptions. There is an ongoing exploration of how to approach the problem, particularly regarding the transition from acceleration to constant velocity.
Participants are working under the constraints of a homework assignment, which may limit the information they can use or the methods they can apply. The discussion reflects a mix of understanding and confusion about the principles involved in the problem.
Effitol840
Im having trouble with a part of a problem. The problem is:
There is an elevator with a mass of 1200[tex]kg[/tex] accelrating upward at 2.1[tex]m/s^2[/tex]. Find T.
For that what I did was [tex]1200 \times 9.8m/s^2[/tex] which gave me 11,760. I then plugged this into [tex]F=ma[/tex] and got 14,280.
The second part of the equation says:
The elevator now moves with a constant upward velocity of 10[tex]m/s[/tex]. Find T.
This is where I get stuck. I don't know how to factor in velocity.
what you've done is plug mg = ma, that isn't right
the gravity is not pulling the elevator down, the elevator is moving upward
that means thhere is some force being exerted by the tension in the cable
taking the upward direction to be postiive
T - mg = ma = Net Force
T = ma + mg
When there is constnat velocity what is the acceleration? So what is the tension using the above equation?
Velocity doesn't affect the force. What you want to think about is acceleration. If it's at a constant velocity, what does that tell you about the net force?
my mistake, your answer is correct.. its just the way you said it sounded like you did something wrong. The first part is correct, follow the advice of finding the acceleration in second part to figure out the tension
Here is the approach I would take:
1. Construct free body diagram of the elevator. Cable tension T is up and elevator weight mg is down
2. Write the equation of motion [itex]\Sigma F = m a[/itex]
3. Case 1: a = fixed value
4. Case 2: if velocity is constant, what can you say about acceleration?
ok so if there is a constant velocity there is no acceleration? Which would just make my answer 11760?
I assume that T is the tension in the cable that pulls the elevator up.
To apply F = ma properly, you need to use the net force on the elevator. There are two forces acting on the elevator: The cable tension pulling up and the weight (mg) pulling down. Find the net upward force (in symbols) and set that equal to ma. Then you can solve for T.
Hint: If the elevator moves at a constant velocity, what must be the net force on it?
Looks like several others beat me to it! :smile:
As long as your units are consistent, I'd say yes.
Yea the answer was 11760. Thanks for the help.
  • · Replies 35 ·
