Power dissipated without a load?
The discussion centers around the concept of power dissipation in an ideal circuit containing voltage and current sources without any resistive loads. Participants explore the implications of having current sources and the conditions under which power can be considered dissipated or absorbed in such circuits.
  • One participant argues that power cannot be dissipated without a resistor, citing the formula P=R*I^2 and noting that R=0 in the absence of a load.
  • Another participant suggests that voltage and current sources can deliver or absorb power according to the equation p=VI, depending on the direction of current flow.
  • Some participants propose that a current source implies an internal resistance, which could affect power dissipation even if the source is ideal.
  • It is noted that in ideal circuits, the internal resistances of current sources are considered infinite and voltage sources have zero series resistance, leading to the conclusion that while power may not be dissipated, it can still be delivered or absorbed by the sources.
Participants express differing views on whether power can be dissipated without a load, with some asserting that it cannot, while others suggest that power can still be absorbed or delivered by the sources. The discussion remains unresolved regarding the conditions under which power dissipation occurs in ideal circuits.
Participants reference idealized models of voltage and current sources, which may not account for real-world behaviors. The discussion highlights assumptions about internal resistances and the implications of circuit configurations.
jsaxton
Greetings,
I recently took an introductory circuits test. The answer key was released today. I am convinced it's wrong, and if my argument is flawed, I'd like to know before bringing it up with the instructor (no, not the professor, the BME guy who appears to apply equations without actually knowing what they mean).
The http://www.ece.umn.edu/class/ee2001/quiz_1a_solution.pdf basically had three idealized voltage sources and a current source. There are no resistors (no load, as far as I can tell). However, power is dissipated in the circuit (according to the answer key). Now, as far as I can tell, this is not possible as P=R*I^2. R=0 (as far as I can tell). Hence no power is dissipated.
I have heard one counterargument: the current source implies a resistance in the voltage source, despite the fact it is ideal. Still how can one dissipate power without a resistor? Am I in the wrong? Can one even have current without a load?
From a physics perspective, what would happen is that the potential differences would simply equal out (we'd get a massive equipotential). Again, as this is an ideal circuit, no voltage would be dropped on the "wires" and no power would be dissipated. Is this reasoning sound?
Thanks,
John
In order to dissipate power you really need a resistor, but the voltage and current sources will be delivering or absorbing power according to p = VI. If the current I enters the higher potential, the power is positive, so the source is absorbing power. If the current enters the lower potential and leaves by the higher one, the source is delivering power.
I am an electronics student as well. The way that I learned it was that a current source implied a resistance that was present even if the source happened to be turned off, i.e. the equivalent circuit to represent the internals is an idealized current source in parallel with a resistor representing internal source resistance (for a voltage source, the internal resistance is in series, so open means no resistance effect).
If the current is turned off, the internal resistance of the current source is still in the circuit, whereas if a voltage source is turned off, you have an open circuit.
In the examples given all sources are ideal, so the current sources have infinite parallel resistances and the voltage sources have zero series resistances.
There is no dissipated power, but there is delivered and absorbed power in each source.
  • · Replies 52 ·
10K
  • · Replies 32 ·
