Identifying Types of Differential Equations: Tips for Beginners
This discussion focuses on identifying types of differential equations, specifically exact, variable separable, homogeneous, and non-homogeneous forms. Key identification techniques include recognizing definitions for homogeneous equations and applying the "cross-condition" for exact equations, where the equation f(x,y)dx + g(x,y)dy = 0 is exact if fy = gx. For separable equations, the identification process involves attempting to separate the variables. It is noted that while every first-order differential equation can theoretically be reduced to a separable form, there is no universal method for determining the necessary integrating factor or change of variable.
  • Understanding of basic differential equations
  • Familiarity with the concept of exact equations and the "cross-condition"
  • Knowledge of homogeneous and non-homogeneous equations
  • Experience with variable separation techniques
  • Study the definitions and properties of exact differential equations
  • Learn how to apply the "cross-condition" for determining exactness
  • Research methods for finding integrating factors for first-order differential equations
  • Explore techniques for changing variables to achieve separability in differential equations
Students and educators in mathematics, particularly those focusing on differential equations, as well as anyone seeking to enhance their problem-solving skills in identifying and classifying different types of differential equations.
shaan_aragorn
Hi all. I need some help here. I want to know, how can one differentiate or identify a type of a differential equation (like exact, variable separable form, reducible to variable separable form, homogenous, non-homogenous form). Please don’t suggest more practice. Are there any tricks to aid the identification?
Note: I am relatively new to DE.
The main trick is knowing the definitions!
Homogeneous equations should be identifiable directly from the definition.
(And, of course, if they don't satisfy that definition, then they are non-homogeneous!)
When you learned about exact equations, you should have learned the "cross-condition" for exactness: the differential equation f(x,y)dx+ g(x,y)dy= 0 is exact if and only if fy= gx. (I call that the "cross-condition" because f(x,y), the function multiplying dx, is differentiated wrt x and vice-versa.)
As for "separable" about the only way to determine that is to try to separate the variables! If the equation is separable, that should be pretty obvious.
Finally, reducible to separable: very easy to answer but you won't like my answer!
Theoretically, every first order d.e. has an "integrating factor" the reduces it to an exact equation and, theoretically, every exact equation can be made separable by a change of variable. So every first order d.e. can be "reduced to a separable d.e.". But there is no general way of finding either that integrating factor or the appropriate change of variable.
  • · Replies 24 ·
  • · Replies 18 ·
  • · Replies 19 ·
