Finding the Initial Velocity of an Egg Thrown Near a Building
The problem involves an egg thrown nearly vertically upward from a point near the cornice of a tall building, which just misses the cornice on its descent and reaches a point 50.0 m below its starting position after 5.00 seconds. The context is kinematics, specifically focusing on motion under gravity without air resistance.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to find the initial speed of the egg and considers the time it takes to travel the 50 m. Some participants suggest using equations of motion and emphasize the importance of defining a consistent sign convention for direction.
Participants are exploring different approaches to the problem, with some offering guidance on using motion equations and clarifying the need for a consistent sign convention. There is no explicit consensus yet, as the original poster is still grappling with the initial velocity calculation.
The original poster has indicated that they are receiving feedback on their answers from an online platform, which may influence their approach to the problem. There is also a mention of splitting the problem into parts, suggesting a consideration of the problem's complexity.
babbagee
An egg is thrown nearly vertically upward from a point near the cornice of a tall building. It just misses the cornice on the way down and passes a point a distance 50.0 m below its starting point at a time 5.00 s after it leaves the thrower's hand. Air resistance may be ignored.
I tried a lot of methods but I keep getting it wrong. I am doing this online so it tells me weather the answer is right or wrong. I tried finding the time it takes to travel the 50m and then subtracting that from the total time to see how long it was in the air from the origin to the time it reaches the origin again. But that did not seem to work. Can someone point me in the right direction. I don't want the answer just give me some hints.
Thanks
You did not state the complete problem. What are you looking for?
sorry about that,
a.) What is the initial speed of the egg?
b.) How high does it rise above its starting point?
the second one is easy once i find the intial speed. So I think i only need help with a.
thanks
You will need to use one of the equations of motions, but you haven't specified what the question is actually asking you. You are probably having problems here because you are not defining which direction is positive. So pick either up or down to be the positive direction. For example, if up is positive and down is negative, then initial velocity is positive, accelleration is negative, total displacement is -50m. As long as you are consistent with your sign convention, you should be able to just put all the values into one of the formulas and get an answer.
It asks for the intial velocity, and I am not having any trouble with my signs. I been using up as positive and down as negative.
Okay so h(t)= -4.9t2+ vt where "v" is the (unknown) initial velocity (yes, + up, -down) and we are taking the height of the roof to be "0". You know that when t= 5, h(5)= -50. Put those into the equation and solve for v.
Hey thanks,
I was thinking of spliting the problem into two parts, but i guess the eqations take that into consideration, right.
