Analyzing Transverse Wave Behavior on a Taut String
The discussion revolves around analyzing the behavior of a transverse wave on a taut string, specifically focusing on determining certain parameters such as amplitude, speed, and direction of the wave based on measured transverse displacements at various points along the string.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • The original poster attempts to calculate values a, b, c, and d using ratios of transverse displacements, while expressing uncertainty about the correctness of this approach. They also explore the relationship between particle velocity and wave speed but encounter inconsistencies due to varying displacements. Other participants suggest using the general wave equation to find parameters A, b, and c, prompting questions about the mathematical tools available for the analysis.
The discussion is ongoing, with participants exploring different aspects of the problem. Some guidance has been offered regarding the general form of the wave equation, but there is no explicit consensus on the methods to be used or the interpretations of the problem.
Participants mention constraints such as the absence of mathematical software and reliance on a summary sheet of important results related to transverse waves. There is also a request for recommendations on textbooks covering relevant topics in wave motion.
big man
The transverse displacement (in cm) of a taut string carrying a sinusoidalwave is measured at points along its length close compared to the wavelength of the wave, and at time intervals small compared with the period of the wave. The results are: SEE ATTACHMENT
Determine the values a,b,c,d, the speed of and direction of the wave, and the amplitude of the wave.
This is the question that I'm having trouble with and I'd appreciate any help here, but first this is what I was thinking:
To determine a,b,c and d I thought that the ratios of the tranverse displacements would be the same. So you would calculate a as follows:
a = [(8.08)/(10.40)]*5.68
b = [(12.62)/(10.40)]*5.68
c and d would be calculated in a similar manner. However, I'm not entirely sure that it's correct.
As for the speed and direction of the wave I don't really have a clue. For the speed of the wave I was trying to use the particle velocity relationship:
particle velocity = dy/dt = c*(dy/dx)
So c = (dy/dt)*(dx/dy)
The problem here is that with my method for calculating the values of a,b,c and d, the displacements (y) are different over the same time interval, which means that I don't get a consistent value for the particle velocity. Also with how the question is setup you can't find the change in the distance along the string with a change in the transverse displacement.
Any help would be great.
Edit: OK I fixed the table, but if you can't see the word document just let me know.
You are told that this is a sinusoidal wave. What is the most general description of a wave that you are given? It should look something like
S(x,t) = A Sin(bx + ct)
What you need to do is to use the information given to find the A ,b and c in the above expression.
What mathematical tools do you have at your disposal?
Yeah I had the sinusoidal bit, but I figured that you'd need to solve for the speed and direction first to then be able to solve for amplitude.
What do you mean by tools exactly?
We don't use any maths programs or anything like that, we just have a summary sheet of important results regarding transverse waves.
I was also wondering if there are any books that are particularly good university textbooks that cover the "Particles and Waves" topics like SHM, transverse wave motion and longitudinal wave motion and that maybe use different approaches (ie Lagrangian, hamiltonian & Newtonian).
Thanks
Well I've handed in the little that I did be it right or wrong :smile:
However, if any of you have time it would be cool to still work through this problem 'cause at least then I would know how to approach questions like this.
Thanks Integral for the initial post as well.
***bump*** anyone up for discussing any aspect of this question? :lol:
  • · Replies 23 ·
  • · Replies 23 ·
