Tricky Word Problem: Solve It with These Tips | Help with Calculations
  • Thread starter Thread starter pqnd1987
    Word problem
The discussion revolves around a word problem involving a block of stone and the process of chipping away at it using a hammer and chisel. The problem specifically focuses on determining how many strikes are necessary to reduce the block to less than half of its original size, given that each strike removes a fixed percentage of the block's mass.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants explore the mathematical implications of retaining a percentage of the block after each strike. Some suggest using exponential decay to model the situation, while others question the interpretation of the problem and the setup of the calculations.
There are multiple interpretations of how to approach the problem, with some participants providing mathematical expressions to represent the situation. Guidance has been offered regarding the formulation of the problem, but no consensus has been reached on the final answer.
There is a mention of the appropriateness of the thread's placement within the forum, indicating potential concerns about categorization. Additionally, the problem involves a specific percentage reduction, which may influence the calculations discussed.
pqnd1987
Tricky word problem.
Hi I'm having trouble figuring out how to approach this word problem and wonder if anyone had tips.
Problem:
Just suppose, for the sake of argument, that you have a large block of stone. While staring at this block of stone, it dawns on you that perhaps you should carve it into something. Luckily, you have a hammer and chisel handy.
But it's no ordinary hammer and chisel. Somehow, no matter how hard you hit the chisel, exactly one-half of one percent of the block chips off.
How many times do you have to hit the chisel before the block is less than half of its original size?
:smile: Basically, since 0.5% is chipped off each successive strike, you thus retain 99.5% of the block on each successive strike.
*You need to find out how many strikes are needed--->how many 0.5% chips are needed to reduce the block to half of its mass.
*Therefore, letting [itex]n[/itex] be the number of strikes thus far, you will retain [itex]\left( {99.5\% } \right)^n[/itex] of the mass after [itex]n[/itex] strikes.
---To find out the minimal [itex]n[/itex] strikes needed to reduce to less than half the mass will require the inequality:
[tex]0.995^n < \frac{1}{2} \Rightarrow n \geqslant \left\lceil {\frac{{\log 0.5}}{{\log 0.995}}} \right\rceil \Rightarrow n \geqslant 139[/tex]
*Thus, the minimum quantity of strikes needed is 139.
(since [itex]n \in \mathbb{N} \cup \left\{ 0 \right\}[/itex]) :biggrin:
(...tho shouldn't this be in the Homework K-12 section? :redface:)
After one blow, there is 1* .995 of the block left. After 2 blows there is 2 * .995 of the block left. So after 'n' blows there is .995^n left. So you need to solve: 0.5=0.995^n
  • · Replies 50 ·
  • · Replies 26 ·
9K
16K
