Car Power to Weight: How Much Extra HP Does Car A Need?
  • Thread starter Thread starter se7en1976
    Car Power Weight
The discussion revolves around comparing the power-to-weight ratios of two cars, where one car (Car A) is heavier than the other (Car B), both having the same horsepower. Participants explore how much additional horsepower Car A would need to outperform Car B in a theoretical race, specifically in a quarter-mile context, while ignoring factors like wind resistance and driver skill.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the significance of power-to-weight ratio and its impact on performance. Some express interest in the underlying equations that govern the relationship between power, weight, and speed. Others question the complexity of modeling real-world factors such as gear systems and traction.
The discussion is active, with participants providing insights into the mathematical relationships involved and questioning the assumptions made. There is a recognition of the need for additional horsepower for Car A to match or exceed Car B's performance, but no consensus on the exact amount or method to calculate it has been reached.
Participants note that the discussion is theoretical and excludes real-world variables such as wind resistance, gearing, and driver skill, which could significantly affect the outcomes. There is also mention of the challenges in accurately modeling engine performance and traction.
se7en1976
I hope this is posted in the right section.
If car A is identical to car B in every way, and both have 100 horsepower.
Only car B weighs significantly less than car A, obviously car B will win a race on the 1/4 mile because being lighter.
Is there a formula that can be worked from to ascertain how much extra horse power car A would need to beat car B??
This is all in a theoretical sense so no extras are taken into account such as gearing, wind resistance, driver skill.
eg: Car A = 1000kg with 100HP and Car B = 750kg and 100HP
How much extra HP does car A require to win.
If no wind resistance, then only the power to weight ratio matters, IOW, car A needs 133 hp to keep up.
Arh right..
I was actually interested in the equation involved so I understand how it works.
If a car of mass [tex]m[/tex] supplies a constant power [tex]P[/tex], then it is increasing it's kinetic energy at the rate [tex]P[/tex]. Starting from rest, the velocity of the car satisfies
[tex] v = \sqrt{\frac{2 P t}{m}}[/tex]
It therefore travels a distance a
[tex] x = \frac{2}{3}\sqrt{\frac{2 P t^3}{m}}[/tex]
in a time [tex]t[/tex]. If car A is heavier than car B then this formula makes it obvious that car A must supply a greater power to traverse the same distance in the same time. As we increase the power provided by car A, there is a threshold where they are able to cross the same distance in the same time. This leads immediately to
[tex] \frac{P_A}{m_A} = \frac{P_B}{m_B}[/tex]
at threshold. If [tex]P_A[/tex] is further increased past this threshold value, then car A will beat car B. This of course reproduces the result of krab since the mass of car A is 4/3 the mass of car B in your example.
power
So being that a cars power is delivered through a system of gears and is not delivered at a constant, the actual equation between two cars would be astoundingly difficult, wouldn't it?
Well if you could determine the rates and timings of the engine's pistons, it's not THAT hard (again, without taking anything else into consideration). But then again I am pretty sure the combustions don't come anywhere near making a sine wave...
I think that se7en1976 wasn't referring to this much detail, but rather that an engine's (potential) output is highly dependent on rpm. That is in turn related to vehicle speed and gear selection.
Anyway, the resulting equations are not "astoundingly difficult" if this is all that's modeled, but they certainly are much more complicated than Physics Monkey's. The big problems come in when you try to take into account traction properly. Any reasonably powerful car is going to be able to spin its tires, and this can be very difficult to model realistically if you want an accurate (few %) 1/4 mile prediction.
10K
9K
