How Do You Convert the Square Root of Two to Binary with Six Decimal Places?
  • Thread starter Thread starter StonedPanda
The discussion revolves around converting the square root of two into binary representation with six decimal places. Participants are exploring the concept of binary as a number system, contrasting it with the decimal system, and discussing the implications of representing fractional values in binary.
  • Some participants attempt to explain the binary system and its differences from the decimal system, while others provide examples of binary representations of fractional values. Questions arise regarding the process of converting the square root of two and the nature of binary fractions.
The discussion includes various explanations of binary and its application to the problem at hand. Some participants have shared insights into the conversion process, while others express curiosity about the underlying concepts. There is an ongoing exploration of how to represent fractional values in binary, with no explicit consensus reached yet.
Participants note that the original poster is new to the topic of binary conversion and is seeking guidance on how to approach the problem. There is an acknowledgment of the complexity involved in converting non-integer values to binary.
StonedPanda
So I'm taking a freshan analysis class. I've never covered converting things to binary and other number systems before, and in a chapter about sequences the book mentions binary and has an exercise to convert the square root of two to six decimal places. Can someone tell me what binary is and to do a problem like that?
well...
you know the way our numbers go:
Well, binary goes different.
Binary is a base-2 system (as opposed to our base-10 system), and is useful because there are only two digits. It forms the basis for every digital system, as 0 and 1 can be compared to "off" and "on" respectively.
Reading a binary system is a bit different. You read it from right to left. A few examples:
00001 = 1
00010 = 2
00011 = 3
00100 = 4
01000 = 8
10000 = 16
Do you see how this works? Each digit from the right is the next power of 2, starting with 2^0 (= 1) at the extreme right.
As for fractional values, binary has none as such. So the closest you can get is whole numbers. (Unless I'm wrong of course :->)
wrong
binary-decimal
1.0=1
0.1=1/2
0.11=3/4
0.01=1/4
0.111=7/8
0.101=5/8
0.011=3/8
a binary number is an expansion of the form
[tex]x=\sum_{n=-\infty}^\infty b_n \ 2^n[/tex]
each bn is either 0 or 1
for real numbers their is an n such that bm=0 for all m>n
for integers bn=0 for all n<0 (in standard form)
lurflurf said:
wrong
binary-decimal
1.0=1
0.1=1/2
0.11=3/4
0.01=1/4
0.111=7/8
0.101=5/8
0.011=3/8
i never knew that! learn something every day!
The binary system tells us about how arbitrary our base 10 system is. We have a total of 10 symbols in our number system:
0,1,2,3,4,5,6,7,8,9
The question is, what would have happened if we only somehow invented two numbers instead of 10, namely, 0 and 1. We would then have binary, and we would have to relearn all our arithmetic, and multiplication tables again (sigh*).
Or what if we invented 16 symbols instead (0,1,2,3,4,5,6,7,8,9,A,B,C,D,E,F) also known as hex? How would our math be different now, having numbers like 41E, and B7A90.
sqrt(2) = 1.4142135623730950488016887242097
First convert the integer part to binary. That's easy. 1 converts to 1.
Now take the remainder, and multiply it by 2 a bunch of times, each time keeping the integer part (which will be zero or one) as the binary bit:
0.8284271247461900976033774484194
1.6568542494923801952067548968388
1.3137084989847603904135097936776
0.62741699796952078082701958735517
1.2548339959390415616540391747103
0.50966799187808312330807834942068
1.0193359837561662466161566988414
0.038671967512332493232313397682708
0.077343935024664986464626795365416
0.15468787004932997292925359073083
0.30937574009865994585850718146166
0.61875148019731989171701436292333
1.2375029603946397834340287258467
0.47500592078927956686805745169332
0.95001184157855913373611490338664
1.9000236831571182674722298067733
1.8000473663142365349444596135466
1.6000947326284730698889192270931
1.2001894652569461397778384541862
0.40037893051389227955567690837245
0.8007578610277845591113538167449
That should be enough for 6 decimal places. The answer is read off the left hand column, namely (and rounding the last bit):
sqrt(10) = 1.011010100000100111101
To check this, just convert it into decimal and square it. Yep, it works.
Another fun thing to do: Figure out what sqrt(2) is to six decimal places written out in base "pi".
Carl
11K
  • · Replies 34 ·
22K
9K
12K
