What Happens to Beet Root Pigments When Cells are Disrupted with Chloroform?
The discussion revolves around the effects of chloroform on beet root cells, specifically regarding the release and behavior of the red pigment betanin when the cells are disrupted. Participants explore the mechanisms of cell membrane disruption, the solubility of betanin, and the expected observations in a laboratory context.
  • Some participants suggest that chloroform, being an organic solvent, could denature the proteins in the cell membrane of beet roots, potentially allowing betanin to diffuse out.
  • Others argue that since betanin is not soluble in chloroform, it may remain inside the cell and not visibly change the solution, leading to a clear test tube.
  • One participant speculates that if the cell membrane is damaged, the contents would leak out, but the pigment would still separate into aqueous and organic phases due to solubility differences.
  • There is a question about whether the phospholipid bilayer of the cell membrane would reverse its orientation in the presence of chloroform, with some participants expressing uncertainty about the mobility of the bilayer configuration.
  • Another participant reflects on their lack of understanding of the specific mechanism by which chloroform disrupts the membrane, noting that they had previously thought of it as simply "poking holes" in the membrane.
  • Some participants discuss the availability of beet root and chloroform, with differing opinions on whether chloroform is accessible to the general public.
Participants express differing views on the solubility of betanin in chloroform and the extent of cell membrane disruption. There is no consensus on the exact mechanisms or outcomes of the experiment, and multiple competing perspectives remain.
Participants acknowledge limitations in their understanding of the specific biochemical interactions at play, particularly regarding the behavior of the phospholipid bilayer in the presence of chloroform and the solubility of betanin.
Artermis
Quote:
Originally Posted by Artermis
Hello Moonbear,
I don't know if you know me but I'm a relatively new member but I know that you are very knowledgeable and helpful, hopefully you'll be willing to help me with this.
Hi, I've seen you in the biology forum recently. Glad to have you on-board.
Quote:
But alas! Betanin and chloroform do not mix together, so the betanin should stay inside the cell and may not diffuse out. There should not be a visible change and the test tube should remain clear.
I don't know this specific example, so can't be entirely sure, but if you're disrupting the cells with chloroform, anything in the cell has to come out. If what comes out (betanin in your example) doesn't mix with the solvent, then it should just separate into two phases, an aqueous phase and an organic phase. The aqueous phase would contain all your water-soluble components, and the organic phase would contain all the hydrophobic compounds.
This is a perfectly good question for the bio forum, so why don't you post it there and see if anyone there has tried this, perhaps as a lab exercise in a class. They might be able to verify if what I think would happen is really what happens.
Cheers,
Moonbear
________________________________________________________
some interesting and helpful sites:
http://www.fed.cuhk.edu.hk/~johnson/tas/investigation/membrane_teacher.htm
For folks who might be confused, Artermis asked me this question via PM and I suggested she post the question out here to get more input.
Here is her full question:
Artermis said:
A few slices of beet root (containing the red pigment betanin, which is very common in high school biology experiments) are submerged into a test tube of 10 mL of chloroform. What happens? Do you observe any red pigment release?
I know you don't help people unless they've done some work and thought about it, so here is my rudimentary analysis:
chloroform is not soluble in water, whereas betanin is. chloroform, because it is an organic solvent, should denature the proteins in the cell membrane of the beet roots and "destroy" the cell membrane (I'm not sure if the cell membrane is actually destroyed but is still there but now easily permeable - the extent of the damage to the cell membrane is eluding me), which should allow the betanin molecules to diffuse (again, not sure about the specific damage done to the cell membrane) out into the chloroform. But alas! Betanin and chloroform do not mix together, so the betanin should stay inside the cell and may not diffuse out. There should not be a visible change and the test tube should remain clear.
That is my thinking, I would really appreciate it if you could clarify. Thank you!
I have not done this experiment, but speculating on what was given and reading the same http://www.fed.cuhk.edu.hk/~johnson/tas/investigation/membrane_teacher.htm you had found (a lot of good insight there), I agree. Once the cell membrane has been damaged, the contents would leak out. Even if the pigment was not soluble in the surrounding medium it would at least be soluable in the aqueous phase. The organic phase should remain clear unless there were some additional unaccounted pigments which dissolved there.
Another thought. If you were to shake the contents of the tube, the two phases would likely mix and form a suspension. Then it would appear that the pigment has mixed with the chloroform until you wait some time and allowed the two phases to re-separate. But from Artermis' description, I don't think this scenerio will happen.
synonyms of betanin: in literature you may find betalain and anthocyanin
Does the phospholipid bilayer reverse when it comes into contact with the chloroform solution? Normally in an aqueous solution like water, heads would be out and tails in, (polar heads, apolar tails) but in chloroform which is a non-polar substance, would the bilayer reverse and have tails out and heads in? Interested in exactly what happens to the bilayer and the extent of change/damage done to it.
I am no biochemist, however my speculation is that this configuration is not mobile. As a bilayer, the hydrophobic edges face inward towards one another, and both hydrophilic edges face outward as in this http://courses.washington.edu/conj/membrane/plbispac.gif. Looking at this configuration, I suspect they are chemically bound in position and cannot flip around.
I really don't know how chloroform disrupts the membrane...I've just known since I don't know when that it does, and never gave much thought to how. I always just thought of it as "poking holes" in the membrane by dissolving the phospholipid bilayer, but I just never gave it enough thought to confirm if that was the mechanism.
As for the rest of the beet root lab, I found explanations of the rest of the lab and expected results on this site:
Beet root has to be available in your neighborhood grocer, and you should be able to buy chloroform from a good pharmacy. Should you not?
I don't think chloroform would be available to the general public. I don't think artermis was asking about where to get the supplies anyway, she was asking the mechanism by which chloroform disrupts the cell membrane, and then what happens to the pigments within the cells that are not soluble in chloroform.
