Solve Ball Drop Problem: Find Initial Velocity
  • Thread starter Thread starter minhngo
    Ball Drop
The problem involves two balls: one thrown upwards from a building and another dropped from the same height one second later. The goal is to determine the initial velocity of the first ball so that both balls hit the ground simultaneously. The context is kinematics, specifically dealing with motion under gravity.
  • Participants discuss the equations of motion for both balls and how they relate to each other. There is an exploration of the time variables involved and how to express one in terms of the other. Questions arise regarding the setup of the equations and the implications of substituting variables.
Participants are actively engaging with the problem, clarifying equations and discussing how to isolate variables. Some guidance has been offered regarding substituting expressions and considering constants, but no consensus on a final approach has been reached.
There is an acknowledgment of the complexity introduced by having two variables (initial velocity and height) in the equations, and participants are considering how to treat height as a constant in their expressions.
minhngo
Hi, I appreciate it if someone can reply and help me out with this problem.
A ball is thrown straight up from the edge of the roof of a building. A second ball is dropped from the roof 1 second later. Air resistance may be ignored.
(a) If the height of the building is H m, what must be the initial speed of the first ball if both are to hit the ground at the same time?
So far I understand that there is:
X(t)=H+Vo(T+1)+1/2(-9.8)(T+1)^2 -> first ball
X(t)=H+1/2(-9.8)(T)^2 -> second ball
Then I know that the two formulas equal each other. From there I found T=(Vo+4.9)/(Vo-9.8)
This is where I get stuck.
You should use T instead of T+1 for the second ball since it is dropped one second after ball one.
Sorry that was a typo. I'll fix it.
From the 2nd eqn, you can get T in terms of H.
Substitute for T into the expression you got stuck on.
I don't really know what you mean by 'the two formulas equal each other'...
You know that when the second ball hits the ground, the first ball will also hit the ground, you have the height, the acceleration, and the initial velocity of the first ball (0 m / s). Can you find how long it takes the second ball to reach the ground? Let say it takes t (seconds) for the second ball to reach the ground.
From there, you know that it takes (t + 1) seconds for the first ball to reach the ground.
You have the first ball initial height, its acceleration, and you know how long it takes to reach the ground. Can you find its initial velocity?
Viet Dao,
What I meant to say was equation is that I set up:
H+Vo(T+1)+1/2(-9.8)(T+1)^2=H+1/2(-9.8)(T)^2
And from there I found T. However I am having trouble finding Vo.
You can get Vo by substituting in for T in terms of H
OK, I am a little confused. If I substitute T in T=(Vo+4.9)/(Vo-9.8) in terms of H, I would still have two variables, Vo and H.
That's right. Your final expression will give Vo as a function of H.
Consider H as an (unknown) constant.
Oh! thanks. I understand now.
  • · Replies 38 ·
