What Is a Precessing Ellipse and How Does It Relate to Orbital Dynamics?
The discussion revolves around the concept of a precessing ellipse in the context of orbital dynamics, specifically examining the gravitational interaction between the sun and the Earth. The original poster presents a force equation and seeks to understand how it leads to a non-closed orbit described as a precessing ellipse.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants explore the definition of a precessing ellipse and its characteristics, questioning how the provided polar equation relates to this concept. There are discussions about plotting the orbit in polar coordinates and the implications of the orbit not being closed.
The discussion is active with various interpretations being explored. Some participants provide insights into the nature of precessing ellipses and suggest methods for visualizing the problem. Others question the assumptions made about the orbit's closure and its mathematical implications.
There are references to specific mathematical forms and potential energy considerations, as well as a mention of constraints related to the nature of the orbits being discussed. Participants also share resources for further exploration of the topic.
siddharth
Suppose that the force of attraction between the sun and the Earth is
[tex]F = GMm(\frac{1}{r^2} + \frac{\alpha}{r^3})[/tex]
Where [tex]\alpha[/tex] is a constant. Show that the orbit does not close on itself but can be described as a precessing ellipse. Find an expression for the rate of precession of the ellipseFirst, of all what is a precessing ellipse?I'm working in polar coordinates [tex]r, \theta[/tex]. Assuming that the sun does not move and is fixed at the orgin of the coordinate system, the equation I get is
[tex]u= \frac{1}{r} = \frac{GMm^2}{L^2}(1+e\cos( A^\frac{1}{2} (\theta - \theta_{0})))[/tex]
Where [tex]A= (1-\frac{GM \alpha m^2}{L^2})[/tex]
So how do I show the above parametric equation (if it is correct) describes a precessing ellipse?
A precessing ellipse is one where the effective semi-major axis rotates or "precesses".
I would start by plotting [tex]r(\theta)[/tex] in polar coordinates if you can. That will make it clear exactly what's going on.
Edit:
Here is a great little applet I just found that plots in polar. Put in some values for you constants and see what happens. http://www.ies.co.jp/math/java/calc/sg_kyok/sg_kyok.html
Presumably one shows that [tex]r(\theta) \neq r(\theta+2\pi)[/tex]
Astronuc, why should that be true?
For example, in the polar equation
[tex]r=\frac{1}{1+\epsilon \cos \theta }[/tex]
The value of [tex]\epsilon[/tex] determines if the equation represents an ellipse parabola or hyperbola. For parabola and hyperbola, even though it is an open orbit
[tex]r(\theta) = r(\theta+2\pi)[/tex]
Be careful, when talking about a hyperbola or parabola going from [tex]r(\theta)[/tex] to [tex]r(\theta+2\pi)[/tex] the orbit passes through infinity. So the orbit is sort of "closed" in a mathematical sense i.e. the particle can "go to infinity" and then return, but you encounter a singluarity on that path. So physicists wouldn't say the orbit is closed since it isn't bounded even though mathematically [tex]r(\theta) = r(\theta+2\pi)[/tex] (in fact the physical particle can never make it around the whole orbit in finite time). In your case the orbit is bounded so it makes sense to ask whether it is closed or not in the sense of Astronuc.
[tex]r(\theta) \neq r(\theta+2\pi)[/tex] because a "precessing ellipse" is not an ellipse! It is close to an ellipse but does not "close". The second time around, the orbit is close to another ellipse with a slightly different major axis. The rate at which that major axes rotates is the "rate of precession".
Have you checked google for "precessing ellipse"? I did and it took about 1 minute to find a complete solution to precisely this problem. I considered posting the website but then decided we should at least make you look it up yourself!
I found the site. Thanks for your help!
The old-fashioned way to look at slowly precessing slightly ellipical orbits is to consider an "effective" potential which includes the angular momentum term (L^2/ 2 m r^2), which then treats the radial motion as 1-d oscillation across a potential-Energy minimum. Its oscillation period (for small amplitude, at least) will be same as orbit period if alpha=0 .
How did you arrive at such a nice parametric form? (didn't check it, but it is clean and looks as though it might even be approximation-free!)
I'm Interested!
lightgrav, write the total energy as
[tex]\frac{mv^2}{2} + \frac{L^2}{2mr^2} + V(r) = E[/tex]
Then set,
[tex]r=\frac{1}{u}[/tex]
So that
[tex]dr/dt= \frac{-L}{m} d\theta /dt[/tex]
then substitue this in I and diff wrt to [tex]\theta[/tex] and cancel out the
[tex]du/d\theta[/tex] and solve the Differential equation.
Can anyone give me the link to the site where the problem has been solved in greater detail? thanking you in anticipation.
phys_learner,
Go to this site for a solution. I worked this out in college many moons ago.
http://www.allenisd.org/facstaff2.nsf/Pages/2114F5695F2377EA86257512005CA02D/$FILE/Symon%203-51.PDF
It's a Symon Classical Mechanics 3rd Edition problem. Hope this helps.
Thank you Chrisk. Now I can find out where I went wrong.
  • · Replies 22 ·
  • · Replies 46 ·
