Solve for Triangle Area and Rate of Change at Time t0 | Geometry Problem
The area of a triangle is calculated using the formula A = 1/2 * b * c * sin(θ). For the given values at time t0, where b0 = 10 inches, c0 = 20 inches, and θ0 = π/3, the area is determined to be 50√3 square inches. The rate of change of the area with respect to b at t0 is 5√3 square inches per inch, while the rate of change with respect to θ at t0 is 50 square inches per radian. To approximate the change in area when θ increases by one degree, the differential method should be applied using the previously calculated rate of change.
  • Understanding of triangle area formulas
  • Knowledge of trigonometric functions, specifically sine
  • Familiarity with calculus concepts, particularly differentiation
  • Ability to convert between degrees and radians
  • Study the application of differentials in geometry problems
  • Learn about the relationship between angle changes and area in triangles
  • Explore the concept of rates of change in calculus
  • Practice solving problems involving trigonometric functions and their derivatives
Students studying geometry and calculus, educators teaching these subjects, and anyone interested in applying mathematical concepts to real-world problems involving triangles.
brad sue
Hi,
I have a problem and I am stuck to one question:
The area of a triangle is given by the formula: A=1/2*b*c*sin(θ )
At time to, we have bo=10 inches, co=20inches, θo=pi/3
a) Find the area of the triangle at to
I found 50*sqrt(3)
b- find the rate of change of the area with respect to b at to.
I found 5*sqrt(3).
c) Find the rate of change of the area with respect with θ at to.
I found 50.
d) Using the rate found in part c) , calculate (by differentials) the approximate change in area if angle theta is increased by one degree.
I need help for this question. I do not know what to do here.
Thank you for your help
I'm guessing that b is the hypotenuse and c is the leg
that adjoins the angle theta.
I notice that you have ignored the UNITS of these...
units are our friends, and keep us in the right dimension.
As the angle increases, b increases in length and the sine of theta increases.
Both of these will increase the area of the triangle.
When you find out how MUCH, it will have units: in^2 .
  • · Replies 33 ·
