Solving \int\int_D (x^4-y^4) dxdy with Optimal Change of Variables
The discussion revolves around evaluating the double integral \(\int\int_D (x^4-y^4) dxdy\) over a specified region D in the first quadrant, defined by the inequalities \(1 \leq x^2-y^2 \leq 3\) and \(2 \leq xy \leq 3\). Participants are exploring appropriate changes of variables to simplify the integration process.
  • Mixed
  • Participants suggest various changes of variables, such as \(u = x^2 - y^2\) and \(v = xy\), and discuss the implications of these choices on the integration region. There are inquiries about calculating the Jacobian and transforming the integrand appropriately. Some participants express challenges in finding the inverse relationships and the resulting expressions.
The conversation is active, with participants sharing insights about the Jacobian and transformations. There is recognition of the complexity involved in the variable changes, and some participants are exploring multiple approaches without reaching a consensus on the best method yet.
Participants are working within the constraints of the problem as posed, including the specific inequalities that define the region D. There is an emphasis on the need for careful handling of the Jacobian and the transformations involved.
Icebreaker
Which change of variable should I use to find:
[tex]\int\int_D (x^4-y^4) dxdy[/tex]
Where D is in the first quadrant with"
[tex]1 \leq x^2-y^2 \leq 3, 2\leq xy \leq 3[/tex]
Try [tex]u = x^2 - y^2[/tex] and [tex]v = xy[/tex] since this makes the integration region simple.
It does, but finding the Jacobian and solving for x and y are almost impossible. Or so I tried.
Yeah, I just gave it a try and it looks that way doesn't it. Not impossible, but certainly a mess on the face of it.
Edit: Ok, a better choice is [tex]u = x^2 + y^2[/tex] and [tex]v = x^2 - y^2[/tex].
It is quite simple:
In order to change variables, you have been taught to calculate the quantities [itex]\frac{\partial{x}}{\partial{u}},\frac{\partial{x}}{\partial{v}},\frac{\partial{y}}{\partial{u}},\frac{\partial{y}}{\partial{v}}[/itex] then form a matrix, and then calculate the determinant of this matrix, right?
But to go from the (x,y) description to the (u,v) description should be the INVERSE of going from the (u,v) description to the (x,y) description!.
Agreed?
Thus, the matrix you seek should be the inverse of the matrix you get by calculating the quantities [itex]\frac{\partial{u}}{\partial{x}},\frac{\partial{u}}{\partial{y}},\frac{\partial{v}}{\partial{x}},\frac{\partial{x}}{\partial{y}}[/itex]
In particular, its determinant is the reciprocal of the other matrix' determinant.
does that help you?
Yes, the Jacobian I have. But how do I get the expression x^4-y^4 from the previous substitution?
Are you talking about [tex]u = x^2 + y^2[/tex] and [tex]v = x^2 - y^2[/tex]? If you are then try multiplying u and v.
No I meant u = x^2-y^2 and v = xy.
Well, if you have calculated correctly, your integrand should now be:
[tex]\frac{x^{4}-y^{4}}{2(x^{2}+y^{2})}=\frac{(x^{2}-y^{2})(x^{2}+y^{2})}{2(x^{2}+y^{2})}=\frac{x^{2}-y^{2}}{2}=\frac{v}{2}[/tex]
Nice, both ways work pretty well.
Ah, of course! Man I should slap myself silly for not seeing that.
I'm not in a habit of slapping others, so I can't help you out on that account.
  • · Replies 105 ·
13K
  • · Replies 40 ·
  • · Replies 27 ·
