Thermodynamic Cycle: Calculating Heat Transfer and Work
The discussion focuses on calculating heat transfer and work in a thermodynamic cycle involving three processes. The initial conditions are defined with pressure p1 at 1 bar and volume V1 at 1.6 m3, transitioning to a final volume of V2 at 0.2 m3. The work done during the compression process (1-2) is calculated as 333 kJ, and the pressure at state 2 (p2) is determined to be 8 bar. The heat transfer for process 2-3 can be calculated using the equation ΔQ = ΔU + W, where ΔU is the change in internal energy.
  • Understanding of thermodynamic cycles and processes
  • Familiarity with the ideal gas law and its applications
  • Knowledge of internal energy and its relation to heat transfer
  • Proficiency in calculus for integrating work done (W = ∫p dV)
  • Study the derivation of the ideal gas law and its implications in thermodynamics
  • Learn about the First Law of Thermodynamics and its applications in heat transfer calculations
  • Explore the concept of enthalpy and its relevance in constant pressure processes
  • Investigate advanced thermodynamic cycles, such as the Carnot cycle and its efficiency
Students and professionals in mechanical engineering, thermodynamics researchers, and anyone involved in energy systems analysis will benefit from this discussion.
kdinser
Sorry about the double post, I had technical difficulties that I was working on and the title of my orginal post got screwed up.
I'm having problems getting started on this one.
A gas undergoes a thermodynamic cycle consisting of 3 processes
process 1-2 compression with pressure(p)*volume(V) = constant, from
[tex]p_{1} = 1 bar[/tex]
[tex]V_{1} = 1.6m^3[/tex]
to
[tex]p_{2} = ?[/tex]
[tex]V_{1} = .2m^3[/tex]
[tex]U_{2}-U_{1}=0[/tex]
process 2-3
Constant pressure to [tex]V_{3}=V_{1}[/tex]
process 3-1
Constant Volume, [tex]U_{1}-U_{3} = -3549kJ[/tex]
There are no significant changes in kinetic or potential energy.
Determine the heat transfer and work for process 2-3 in kJ.
I don't have any problems finding[tex]p_{2}[/tex] or the work needed to compress the gas, but I'm not really sure where to go from there.
[tex]p_2=\frac{p_1V_1}{V_2}[/tex]
[tex]W=\int p dV[/tex]
When I work these out, I end up with 333kJ for W and 8 bar for p2.
If someone could give me a quick push in the right direction, that would be great.
to
process 2-3
process 3-1
The work done between 2-3 is just [itex]P_2\Delta V = P_2(V_3-V_2) = P_2(7*V_2)[/itex]
The change in internal energy is [itex]U_3-U_2 = U_3-U_1[/itex], since [itex]U_2=U_1[/itex]
Use [itex]\Delta Q = \Delta U + W[/itex] to find the energy (heat) flow into the system.
AM
