How Do You Calculate the Ionization Energy of Hydrogen Using Quantum Mechanics?
The calculation of the ionization energy (IE) of hydrogen using quantum mechanics involves the equation E = -2.178 x 10^-18 (Z^2/n^2), where Z is the atomic number and n is the principal quantum number. For hydrogen, Z equals 1, leading to E = -2.178 x 10^-18 (1/n^2). The ionization energy can be calculated as approximately 1312 kJ/mol, which is consistent with the experimental value of 1310 kJ/mol, confirming the accuracy of the method used.
  • Understanding of quantum mechanics principles
  • Familiarity with the concept of atomic energy levels
  • Knowledge of the equation for energy levels in hydrogen
  • Basic proficiency in unit conversions (J to kJ/mol)
  • Study the derivation of the Rydberg formula for hydrogen
  • Learn about the significance of quantum numbers in atomic structure
  • Explore the concept of ionization energy in other elements
  • Investigate the experimental methods for measuring ionization energy
Students and professionals in physics, particularly those focused on quantum mechanics and atomic theory, as well as chemists interested in ionization energy calculations.
erik05
Hello everybody, just wondering if anyone could point me in the right direction for this question. Please and thanks.
1) Since the ionisation process takes an electron from its ground state to the zero level of the energy scale, the ground state energy calculated for the electron of the hydrogen atom can be compared to the negative of its ionization energy (IE). Use the equation E= -2.178 x 10^-18 (Z^2/n^2) for energy of a valence level n, to build a equation that can be used to calculate the ionisation energy of H in units of kJ/mol.
So far what I have is...
Since Z represents the atomic number and the atomic number for hydrogen is 1:
E= -2.178 x 10^-18 (1^2/n^2)
so equation is E= -2.178 x 10^-18 (1/n^2)
2) Use equation to calculate ionization IE for H and confirm that value obtained is consistent with the experimental value of 1310 kJ/mol.
E= -2.178 x 10^-18 (1/ (1-0)^2) since electron going from ground state to zero level therefore:
E= -2.178 x 10^-18 J per 1 atom. So then,
E= -2.178 x 10^-18 J/atom x (6.022 x 10^23 atom/mol) / 1000
= -1312 kJ/mol
Your answer is correct, but there is a tiny error in the way you've substituted in the formula.
Where did you get 1/(1-0)^2 from ? The ionization energy is the energy difference between the first shell and an infinitely removed shell. So the shell dependence goes like [itex]1/n_1^2 - 1/n_2^2 = 1/1^2 - 1/\infty^2 = 1 - 0 = 1[/itex]. The rest is good.
PS : Didn't I answer an almost identical question recently ?
EDIT : Found it : https://www.physicsforums.com/showthread.php?t=93440
10K
61K
68K
20K
