Calculating Speed at Equator: 91.3kg Person
  • Thread starter Thread starter AdnamaLeigh
    Equator Speed
The discussion revolves around calculating the speed of a 91.3kg person at the equator, using the equations for centripetal force and gravitational force. The user correctly set the equations as (m2v^2)/r = (Gm1m2)/(r^2) with m1 as Earth's mass (5.98e24kg), m2 as the person's mass (91.3kg), and r as the Earth's radius (6.37e6m). The calculated orbital speed of 7914.584m/s is accurate for achieving weightlessness, but the actual rotational speed at the equator is significantly lower. The mass of the person cancels out in the equation, emphasizing that the calculation pertains to orbital mechanics rather than the person's weight.
  • Understanding of centripetal force and gravitational force equations
  • Familiarity with the universal gravitational constant (G = 6.67259e-11)
  • Knowledge of Earth's mass (5.98e24kg) and radius (6.37e6m)
  • Basic principles of orbital mechanics
  • Research the actual rotational speed of the Earth at the equator
  • Learn about the concept of orbital velocity and its implications
  • Explore the relationship between mass and gravitational force in physics
  • Investigate the effects of Earth's rotation on objects at the equator
Students and educators in physics, aerospace engineers, and anyone interested in understanding the dynamics of motion related to Earth's rotation and gravitational forces.
AdnamaLeigh
I thought I set up the equations correctly, but the speed I got seemed too fast.
An early objection to the idea that the Earth is spinning on its axis was that Earth would turn so fast at the equator that people would be thrown into space. Show the error in this logic by calculating the speed of a 91.3kg person at the equator.
I set the equations for centripetal force and gravitational force equal to each other:
I set m1 = Earth's mass and m2 = person's mass
r was given: 6.37e6m
mass of earth: 5.98e24kg
G = 6.67259e-11
I solved for velocity and got 7914.584m/s and that seems too fast. I'm worried because they also provided the moon's radius in the givens, I hope I wasn't supposed to use that because I can't find any use for that.
Your answer is correct for the speed you would need to exceed in order to be thrown into space(or to be more precise, into Earth orbit). Now compare it to the actual speed at the equator.
I'm not sure what you're trying to calculate but it appears you calculated how fast a person near the equator would have to travel in order to "be in orbit" or to be weightless. The speed you calculated is correct. Did you notice how the mass of the person cancels from both sides of the equation?
The question is a little unclear and it appears to ask how fast a person standing at the equator moves -- due to the rotation of the Earth. In relation to the context given it would further seem you would have to compare that number with the one you calculated above.
  • · Replies 23 ·
