Find domain of (2+x-x^2)/((x-1)^2)
  • Thread starter Thread starter bobboxx
    Domain
The discussion revolves around finding the domain and various characteristics of the function (2+x-x^2)/((x-1)^2), including intercepts, asymptotes, critical numbers, and points of extremum.
  • Participants discuss the identification of critical numbers and asymptotes, with some expressing uncertainty about their findings and the implications for increasing or decreasing behavior of the function.
Some participants have provided guidance on checking the signs of the derivative to determine increasing or decreasing intervals. There is ongoing exploration of the nature of critical points and the role of vertical asymptotes in the analysis.
Participants note the need to adhere to homework guidelines and the importance of not providing complete solutions, which may influence the direction of the discussion.
bobboxx
Could someone find the domain, intercepts, asymptotes, critical numbers, local min and max, absolute min and max, concavity, and inflection points of the function: (2+x-x^2)/((x-1)^2)
Thank you it would be much appreciated
We help out here, not do things for you. What do you know about these or what have you done so far?
I have found a critical number at x=5 but I don't know if that is correct.
I have a vertical asymptote at X=1 and a horizontal at y=-1
My derivative of the function is (x-5)/(x-1)^3 but I am not sure f this is right either.
I don't know which points to use to tell if it is increasing or decreasing-do I use five and 1?
Since x = 5 is a zero of the derivative, so f'(5) = 0, it is indeed a stationary point. You still need to check whether this is an extremum (and then max or min) or not.
Both correct.
The derivative is correct as well.
A function is rising where its derivative is positive, a function is decreasing where the derivative is negative. So check the sign of f'(x).
f'(5) is neither a minimum or a maximum
Why is this a critical number? The graph is increasing to the left of -1 and decreasing to the right of -1. The graph is not changing at 5.
Since you derivative f'(x) = (x-5)/(x-1)^3, x = 5 is a zero of f'(x) so f'(5) = 0, therefore x = 5 is a stationary point which means the tangent line is parallel to the x-axis there. This may be a minimum, maximum or a point of inflection.
Do you know what it is?
I think I figured it out.
f(5) would be a local minimum
I think I messed up because I choose f(0) as a point to the left of f(5) instead of a point in between 1 and 5.
Do you have to include your vertical asymptotes when you are trying to find out if the function is increasing or decreasing?
If yes, this is where I messed up. Thanks for your help.
There is indeed a minimum at x = 5, that's right :smile:
Well, I don't know what you have to do but when we had to find vertical asymptotes, we also had to check whether the function approached infinity or -infinity to the left and right of the asymptote.
Thanks appreciate it
You're welcome, if there's anything else - do ask :smile:
Yes, but ask in the Homework section of this site, which is located at the top.
The Math section is not for homework questions, as is clearly explained in the notice posted there entitled "Homework".
