Find Initial Separation d for Mass-Spring System: Energy & Force | 4245 N/m
  • Thread starter Thread starter ViewtifulBeau
    Energy Spring
The discussion focuses on calculating the initial separation distance d for a mass-spring system involving a 21.4 kg mass sliding down a 35.6-degree incline and compressing a spring with a force constant of 4245 N/m. The user initially calculated the potential energy (PE) of the block after compression to be 123.584 J using the formula 1/2 kx^2. However, the user miscalculated the distance d along the incline by only considering the vertical height h instead of the hypotenuse. The correct approach involves using the sine function to convert the vertical distance to the incline distance.
  • Understanding of potential energy in spring systems (1/2 kx^2)
  • Knowledge of gravitational potential energy (mgh)
  • Basic trigonometry, specifically sine functions
  • Familiarity with mass-spring dynamics
  • Review the derivation of potential energy in spring systems using 1/2 kx^2
  • Learn how to apply trigonometric functions to resolve distances in inclined planes
  • Study the principles of energy conservation in mass-spring systems
  • Explore examples of similar mass-spring problems to reinforce understanding
Students and educators in physics, engineers working with mechanical systems, and anyone interested in understanding the dynamics of mass-spring systems on inclined planes.
ViewtifulBeau
A 21.4 kg mass starts from rest and slides a distance d down a frictionless 35.6 degree incline where it contacts an uncompressed spring of negligible mass, as shown. The mass slides an additional distance 0.2413 m as it is brought momentarily to rest by compressing the spring (force constant k = 4245 N/m). Find the initial separation d between the mass and the spring.
i used 1/2 kx^2 to find the PE of the block after being compressed to be 123.584 J. then i used mgh to find h. so 123.584/(35.6*21.4) = 1.011 m... but its not right. what did i do wrong? thanks.
You found the vertical distance h that is traversed, what they are asking for the the distance d along the incline it travels. You have the y-component of the distance, now you have to calculate the hypoteneuse which is d.
You did everything right, you just didn't take the final step.
so i divided 1.011 by sin 35.6 but it is still not right. (1.7367)
  • · Replies 58 ·
