Struggling to Solve Chain Rule Problem: Help Appreciated!
  • Thread starter Thread starter roe
    Chain Chain rule
The discussion centers on solving a chain rule problem in calculus, specifically finding dy/dx for the function y = (s+3)^2, where s = sqrt(t-3) and t = x^2. The correct application of the chain rule is crucial, particularly in deriving ds/dt, which should be 1/(2*sqrt(t-3)) instead of 1. The final correct answer for dy/dx at x = 2 is confirmed to be 16, aligning with the textbook solution after correcting the derivative of the inner function.
  • Understanding of the chain rule in calculus
  • Familiarity with derivatives of composite functions
  • Knowledge of basic algebraic manipulation
  • Ability to substitute variables in functions
  • Review the chain rule in calculus with a focus on composite functions
  • Practice finding derivatives of nested functions
  • Explore examples of applying the chain rule in different contexts
  • Learn about common pitfalls in derivative calculations and how to avoid them
Students studying calculus, educators teaching calculus concepts, and anyone looking to improve their understanding of the chain rule and derivative calculations.
roe
I'm thoroughly confused as to how and work this problem. I thought I had an ok understanding of the chain rule when I started the section's homework, but this question has me ready to gorge out my eyeballs!
The Problem:
Find:dy/dx at x = 2
Given: y = (s+3)^2, s = sqrt(t-3), t = x^2
OK, So from what I understand, in this case dy/dx can be found using the chain rule, which is:
dy/dx = dy/ds * ds/dt * dt/dx
dt/dx is easy, and is just 2x. sqrt(t-3) looked trickier to me at first, but I'm getting it to be 1 (sqrt(t-3)' = sqrt(1-0) = 1, correct?). I've worked out (s+3)^2 two different ways, getting the same answer both times:
((s+3)(s+3))' = (s^2 + 6s + 9)' = 2s + 6 = 2(s + 3)
--or--
say y = h(s), f(s) = s^2, g(s) = (s+3)
then f'(s) = 2s and g'(s) = 1
h'(s) = f'(g(s))*g'(s) = f'(s+3) * 1 = 2(s+3) * 1 = 2(s + 3)
So I'm fairly certain that dy/ds is 2(s + 3).
Now I know that dy/ds is 2(s+3), ds/dt is 1, and dt/dx is 2x. Now I can multiply:
2(s+3) * (1) * (2x) ----> and put s+3 in terms of x by substituting:
2(sqrt(t-3) + 3) * (1) * (2x) -----> 2(sqrt(x^2 - 3) + 3) * (1) * (2x)
And finally, set x == 2:
2(sqrt(2^2 - 3) + 3) * (4) = 2(sqrt(1) + 3) * (4) = 2(1 + 3) * 4 =
2(4) * 4) = 8 * 4 = 32! The book's answer is 16, so I'm making a mistake somewhere but I'm having difficulty figuring out where. Any help is appreciated!
Not correct actually. The chain rule applies here and tells you to derivate the outer function first and then multiply by the derivative of the inner function. The outer function in your case is the square root, while the inner function is t-3. Therefore (sqrt(t-3))' = 1/(2*sqrt(t-3)). This is very much the same to what you did to find dy/ds (2nd method), which is correct by the way.
All the rest is correct, and if you redo your calculations with the right ds/dt, you should indeed get 16.
Aha! So, if I say:
h(x) = sqrt(t-3) = (t-3)^.5
f(t) = t^.5
g(t) = t-3
f'(t) = .5(t)^-.5
g'(t) = 1
so:
h'(t) = f'(g(t)) * g'(t) -------->
h'(t) = f'(t-3) * 1 -------->
h'(t) = 1/2 * (t-3)^(-1/2) ----> h'(t) = 1/2 * 1 / sqrt(t-3) ------->
h'(t) = 1 / 2 * sqrt(t-3), then I solved for x = 2 and got 16. Thank you so much for making this clear!
  • · Replies 105 ·
13K
