Find the x component for the force parallel using xcos
The discussion revolves around a physics problem involving a block on an inclined plane, specifically focusing on calculating the force parallel to the incline and related concepts such as acceleration and friction. The problem is set within an introductory physics context.
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants are discussing the components of forces acting on the block, particularly questioning the definitions of variables used in the expression for the force parallel to the incline. There is a suggestion to draw a free body diagram and resolve forces accordingly.
The discussion is ongoing, with participants seeking clarification on the variables involved and emphasizing the importance of visualizing the problem through diagrams. Some guidance has been offered regarding the resolution of forces and the application of Newton's Second Law.
There is mention of a lack of clarity regarding the definitions of "x" and "theta" in the context of the problem, which may affect the understanding of the force components. Additionally, the original poster has indicated a need for help with multiple aspects of the problem, including friction and acceleration.
lilkrazyrae
A block weighing 95.0 lbs is on a 34.5 degree plane. Find the force parallel to the plane, the acceleration if there is no friction, the coefficient of friction if the object is just at the point of sliding, and the acceleration if coefficient of sliding friction is .350.
Do you find the x component for the force parallel using xcos(theta)? I need some help with the rest!
1. This is an Introductory Physics question.
2. In "xcosy" what are x and y ? :confused:
3. You need to study your textbook chapter on resolution of vectors.
4. There are some tutorials you can look into here : https://www.physicsforums.com/forumdisplay.php?f=151
PS : It's good practice to use a descriptive title like "block on incline".
I've moved this from the Advanced Physics forum.
hey i meant theta but there is no key for that so i substituted y
Okay, but you still have to tell us what "x" and [itex]\theta[/itex] refer to. Depending on that, your answer (so far) could be right or wrong.
Please try and communicate all the information, in as clear a manner as possible.
1. Did you draw the free body diagram ? Do not write down any equations unless you've done this.
2. What are all the forces acting on the block ? If some of these forces are not acting along a direction parallel or perpendicular to the incline, resolve these forces along these directions.
3. Apply Newton's Second Law to each direction, after finding the net force in that direction.
  • · Replies 38 ·
