Solving a Baseball Word Problem: Time in Air & Height of Ball's Path
  • Thread starter Thread starter RHSLilSweetie07
    Word problem
The discussion revolves around a baseball projectile motion problem involving a ball thrown at an angle with a specific speed and distance. Participants are exploring how to determine the time the ball is in the air and the maximum height it reaches during its flight.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss breaking down the velocity into its x and y components and the implications of gravity on the ball's motion. There are attempts to clarify the assumptions regarding the height from which the ball is thrown and caught. Some participants suggest using specific formulas and methodologies for projectile motion, while others question the understanding of the principles involved.
There is ongoing exploration of different approaches to the problem, with some participants offering guidance on how to think about the components of motion and the importance of understanding the underlying principles. A few participants have shared their calculated values for time and height, prompting further discussion about the correctness of these results and the methods used to obtain them.
Participants note that the problem may be at a high school level and express concern about ensuring a solid understanding of the concepts rather than just obtaining answers. There is also mention of external resources and tutorials that could aid in understanding the problem better.
RHSLilSweetie07
A baseball is thrown at an angle of 24 degrees relative to the ground at a speed of 29.3 m/s. The ball is caught 65.0 m from the thrower. The acceleration of gravity is 9.81 m/s^2.
a) How long is it in the air? Answer in units of s.
b) How high is the tallest spot in the ball's path? Answer in units of m.
I have no clue on how to solve this problem. Will someone please help, or at least give me the formula to use.
Thanks
When I help people I know with ballistics-esque problems I always try to get them to understand that the ball doesn't change velocity in the x direction , because we ignore air friction for simpler physics...and since the ball has gravity applied to it, it will be what 'limits' the range. Like.. when the scenario is taking place, the ball is moving, what dictates when it stops is when the y component reaches its desired height, now since it doesn't mention anything about the ball being caught by someone taller or shorter.. or landing on the ground, you have to assume that the level from which the ball is released is the same as where it is caught, AND that this is the 0 for your height.
First, I'd find the vector components of the velocity of the ball. Since velocity is a vector, and you're taking it at the instant that the ball is released, you do not need to fret over the arc path that the ball will travel.
So, you can treat it like finding the x/y components of any simple vector.
v_x = 29.3 cos(24)
v_y = 29.3 sin(24)
Now, you want to figure out the amount of time it takes for the ball to accelerate from its v_y to 0 , since the same acceleration is being applied and the displacement of the ball is the same, then the time up will equal the time down, in one instance you're subtracting your v_y and in the other you're subtracting 0 from v_y , the one where you subtract v_y will have a negative accel, the other a positive.. so in the end it cancels out.
Now, since we assume the v_x doesn't change then the 'range' of the object is going to be the displacement that occurs over the time you find for the object to go up and down, at a rate of v_x.
Sorry if the wording is a little tricky, I'd rather not just hand you an answer.
using some of the simple formulas you can work to your answer. One place you might want to go is http://scienceworld.wolfram.com/physics/Ballistics.html
that page is pretty much blank, but the 'related to ' links will help you.. I didn't want to just put a bunch of them in here.
If this doesn't give you the nudge you need then just ask for clarification or something, or let me know how far you got and i'll see if i can't nudge a little more..
If your physics class is calculus based, pls see the following link for a tutorial I wrote specifically for this forum that illustrates a simple, structured methodology for dealing with problems like this. It includes a sample projectile problem (3rd attachment, I think), which is what you have.
https://www.physicsforums.com/showthread.php?t=93670
I think perhaps the more important question is whether you understand the principles involved and the methodology to achieve the anwser.:smile:
hotvette: I doubt the class is directly calculus based, its probably a HS level or so class, but that is a nice one, I'm going to use it :-D
RHS : Hotvette is exactly right, if all you know is whether or not your numbers are right, then all you know is the answers for this problem. If you ensure that you understand how to manipulate formulas and stuff to get to your answer, then you can answer any problem (on the topic).
I got a different number for the time. If you know acceleration, and you know the change in velocity then what you want to do is find a formula that uses a (accel), (delta) v (change in veloc), and delta t (change in time).
One thing I did in my first physics class is I would always crack open my book at least once a day and write the equations in the 'base forms' that they were given (not like there is a 'base form' but the way they were given) and i would just algebra it up and solve for each variable in each one.. and then use substitution to solve for variables across equations. After a few days I'd know the equations in the book, and how to use them together to get to where I wanted to be (<variable desired> = <expression with variables that have known values>)
you might want to try and find your own method of solving it rather than going to that place and just copying their work. If you do that, then all you did was follow steps, but you're not given steps when the problems matter a little more.
stmoe said:
One thing I did in my first physics class is I would always crack open my book at least once a day and write the equations in...
As a study aid for final exams, I used to write tutorials with detailed example problems explaining each step!
