Linear Independence of Solutions in Second Order ODEs
The discussion revolves around the linear independence of solutions to a second-order linear differential equation, specifically examining the equation w'' + (4/x)w' + (4/x^4)w = 0. Participants explore the nature of solutions and the implications of linear combinations of functions within the context of this differential equation.
  • Participants discuss the requirement for two independent solutions and question whether each function in a linear combination must individually satisfy the differential equation. There is an exploration of the implications of linearity in differential equations.
The discussion has highlighted differing views on the nature of solutions to the differential equation. Some participants have provided insights into the conditions under which functions can be considered solutions, while others have pointed out specific examples that challenge initial assumptions. Guidance has been offered regarding potential methods to find additional solutions.
There is an ongoing examination of the definitions and properties of linear combinations of solutions, as well as the implications of linearity in the context of the given differential equation. Participants are also considering the potential need for additional solutions beyond those initially presented.
Clausius2
Assume the next differential LINEAR second order equation:
[tex]w''+\frac{4}{x}w'+\frac{4}{x^4}w=0[/tex]
So I thought: OK, I need two independent solutions [tex]w_1[/tex] and [tex]w_2[/tex], because the space of solutions is of dimension two.
Then the professor gave us a solution:
[tex]w=sen(2/x)-(2/x)cos(2/x)[/tex]
and I thought: Ok, the solution he's giving us is composed by two linearly independent functions (because doing the wronskian it does not becames zero anywhere), and therefore each function must be solution of the differential equation..
Is this last bolded statement true for any second linear ODE??.
Well, just try it out, and you''ll find that [tex]\sin(\frac{2}{x})[/tex] is NOT a solution of your diff.eq.
Of course I tried it, and I realized of it. But I really thought that in a set of solutions [tex]c_1w_1+c_2w_2[/tex] in which w1 and w2 are linearly independent functions, w1 and w2 must satisfy EACH ONE the ODE.
No, no, Clausius2.
Suppose a solution S of a diff. eq can be written in terms of two functions, S=f+g.
Let us assume that the diff.eq is linear and homogenous.
Let L be our differential operator, so that we have LS=0.
From this, we have Lf+Lg=0
It by no means now follows that we must have Lf=Lg=0!
We can, for example let Lf=H=-Lg
where H is some function.
But then we have for example that Lf=H, that is f is NOT a solution to your original differential equation, Ly=0 (for which S is a solution).
Any linear combination of solutions of a linear homogeneous DE is also a solution. However, not all solutions given, are linear combinations of solutions. Your solution above does not appear to be a linear combination of solutions. Thus I would suppose there is another solution such that:
[tex]w(x)=A[Sin(2/x)-2/xCos(2/x)]+Bg(x)[/tex]
Me, I'd multiply by [itex]x^4[/itex], review power series, and figure out what that other solution is . . . just might. :smile:
Edit: I'd try reduction of order first.
OK. Thanks very much both of you. I've understood the point. :smile:
  • · Replies 18 ·
  • · Replies 21 ·
