Finding the unit tagent vector, normal vec and curvature problem
The discussion focuses on calculating the unit tangent vector, normal vector, and curvature for the curve defined by the parametric equation r(t) = <1/3 * t^3, 1/2 * t^2, t>. The correct formula for the unit tangent vector T(t) is T(t) = r'(t)/|r'(t)|, while the unit normal vector N(t) is derived from N(t) = T'(t)/|T'(t)|. A common mistake highlighted is using r' instead of T when calculating N(t). The curvature can be determined once T(t) and N(t) are correctly established.
  • Understanding of parametric equations in calculus
  • Knowledge of vector calculus, specifically derivatives
  • Familiarity with the concepts of unit vectors and curvature
  • Ability to perform vector normalization
  • Study the derivation of curvature for parametric curves
  • Learn about vector normalization techniques in depth
  • Explore advanced topics in vector calculus, such as Frenet-Serret formulas
  • Practice problems involving unit tangent and normal vectors in different contexts
Students and professionals in mathematics, physics, and engineering who are working with curves and require a solid understanding of vector calculus concepts.
mr_coffee
Hello everyone, the problem says to:
For the curve gien by r(t) = <1/3* t^3, 1/2 * t^2, t>
find (a) The unit tagent vector;
(b) the unit normal vector;
(c) the curvature;
Well it seems easy enough! the formula's are just derivatives for instance:
The unit tagent vector says:
T(t) = r'(t)/|r'(t)| i got this one right, you can see my work on the image below:
but part (b) i missed..
The normal vector N is suppose to just be:
N(t) = T'(t)/|T'(t)|;
Here is my work and it does not match the back of the book.
http://show.imagehosting.us/show/800636/0/nouser_800/T0_-1_800636.jpg
In finding N, you did NOT find T'/|T'|. You used r' rather than T.
Yes, [tex]T= <t^2, t, 1>/\sqrt{t^4+ t^2+ 1}[/tex].
To find N(t) you have to differentiate THAT: differentiate
[tex]\left<\frac{t^2}{\sqrt{t^4+ t^2+ 1}},\frac{t}{\sqrt{t^4+ t^2+ 1}},\frac{1}{\sqrt{t^4+ t^2+ 1}}\right>[/tex].
  • · Replies 85 ·
10K
  • · Replies 22 ·
