Binomial Theorem - small values of x and approximate values
The discussion revolves around the application of the binomial theorem to approximate the function (1+x)^(-1/2) for small values of x, specifically in the context of calculating an approximate value for 1/root(1.01).
  • Participants discuss the initial requirement to show the approximation and how to apply the binomial theorem. There are attempts to clarify the setup of the problem, including identifying the values of a and b in the context of the binomial expansion.
The discussion is ongoing, with participants providing guidance on using the binomial theorem. Some questions remain about the initial "show that" requirement and the specific values used in the approximation process.
There is mention of confusion regarding the example provided in the homework, and a participant expresses uncertainty about the reference to 1.01/0.01, indicating a potential misunderstanding or miscommunication in the discussion.
Bucky
"Show that for small values of x, the function (1+x)^(-1/2) may be approximated by
1-(1/2)x+(3/8)x^2
Hence obtain the approximate value of 1/root(1.01) to 4 decimals."
im totally clueless. the example we have isn't well explained at all. can someone even just start me off?
(incidentally what happened to the flex pluggin? i went to find it for the maths bits but can't find it)
Just replace x with 0.01 in your binomial expansion and you will have the desired approximation.
what about the initial 'show that' bit?
Do you know the binomial theorem?
(a+b)^n = a^n +na^(n-1)b + (n(n-1))/2! (etc) ...that one?
That's the one!
Now you have 1.01 , think of it as a+b where a=1 and b=.01.
Now, plug that into the binomial expansion, look at the magnitude of each monomial as you add them, continue until the terms are below your desired error.
ok thanks for your help guys..just one more question..
where did you get 1.01/0.01 from?
?? I don't see any reference to 1.01/0.01 in any of the previous responses!
