Linear Algebra - Hermitian matrices
The discussion revolves around properties of Hermitian matrices and their implications in linear algebra, specifically focusing on the correctness of various statements related to matrix diagonalizability and Hermitian properties.
  • Conceptual clarification, Assumption checking, Mixed
  • Participants explore the validity of several statements regarding Hermitian matrices, questioning definitions and properties such as diagonalizability and the nature of matrix transpositions.
The conversation has evolved with participants initially expressing uncertainty about certain statements, leading to attempts to verify their correctness through examples and proofs. Some participants have shifted their positions based on new insights gained during the discussion.
Participants are working under the constraints of an exam context, which may influence their interpretations and assumptions about the properties of matrices discussed.
big man
Sorry if this is in the wrong section. I just want to check my answer since I've been going through the exam.
Given that A is an n × n matrix and I is the n × n identity matrix, select all the correct responses below.
A Every diagonalisable matrix is normal.
B If A is Hermitian, then [tex]A^TA[/tex] is also Hermitian.
C If all eigenvalues of A have algebraic multiplicity 1, then it is diagonalisable.
D If A is Hermitian, then A + I is always invertible.
E If B = A*A, then B is Hermitian.
F None of the above
I know that A is wrong because it is only every unitarily diagonalisable matrix that is normal. I think B is correct because if it is Hermitian it means that A is equal to the complex conjugate of the transpose. So really A is a symmetric matrix and [tex]A^T=A=A^*[/tex]. Not too sure about C in the end. I think D is wrong because the Hermitian matrix doesn't have to be invertible to begin with. E is also wrong because you don't know enough information about the matrix B to make that statement. Obviously the selection then can't be "none of the above".
I think I might have them right, but I would like to check. ALthough I don't actually know about C so if someone could explain that to me I'd be grateful.
Thanks
No, A need not be symmetric. Where did you get that from ? It doesn't say anywhere that A is real.
PS : You are correct that choice A (all diag matrices are normal) is wrong.
Oh I just thought that any matrix where [tex]A^T=A[/tex] is called a symmetric matrix.
That's right, but where is that given in the question ?
Ahh wait yeah I'm an idiot...I just took something out of the statement that wasn't there. It doesn't equal just A transpose. It's only the complex conjugate of the transpose. OK so B is actually wrong as well.
For the ones you think are wrong, have you tried coming up with a counterexample?
haha thanks for that. I just tried some examples for E and found that it was true. Also found a proof in the notes that C was true so that was good. So yeah I found that C and E are the actual answers (I'm pretty damn sure about this)...can't believe how off my answers were at the beginning.
Thanks again
11K
  • · Replies 25 ·
