Probability: 2 People Have Bags of 60 Marbles
  • Thread starter Thread starter dnt
    Probability
The problem involves two people each drawing 20 marbles from bags containing 60 uniquely numbered marbles. The main question is about calculating the probability that at least one number matches between the two sets of drawn marbles. There is also a secondary question regarding the probability of matching at least 10 numbers.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the method of calculating the probability of no matches and subtracting from one. There are attempts to derive the expression mathematically and questions about the correctness of the approach. Some participants express confusion about the probabilities involved when considering multiple draws.
The discussion is ongoing, with participants exploring different interpretations of the probability calculations. Some guidance has been offered regarding the initial approach, but there is no explicit consensus on the correct method or outcome. Confusion persists around the implications of drawing without replacement.
Participants are grappling with the complexities of probability in a scenario involving dependent events, specifically the impact of drawing marbles without replacement. There is a mention of a secondary condition regarding matching at least 10 numbers, which adds to the complexity of the discussion.
dnt
two people have bags of 60 marbles, each numbered 1 though 60.
each pulls 20 marbles...what is the probability that they match at least one number.
the way i did was figure out what are the chances they match none and subtract that from 1:
1 - [(40/60)(39/59)(38/58)...(22/42)(21/41)]
is that correct?
now what if it was match at least 10 numbers...i can't figure that out.
is that correct?
Your logic is correct.
Prob{at least 10 matches} = 1 - Prob{exactly 0 matches or exactly 1 match or ... or exactly 9 matches}
is my math correct for the first question?
I am guessing, yes.
Go ahead and write out your math (express in words) for my benefit if you don't mind. Or just derive that expression from some kind of principle.
well i think it should be 1 - [(40/60)(39/59)(38/58)...(22/42)(21/41)]
which turns out to be 1 - [(40!/20!)/(60!/40!)] = 1 - [[(40!*40!)/(20!*60!)]
which is like >99.99%.
is that right?
I have drawn 20 marbles. I label them A through T.
"A" has a number on it. What is the prob. that that number is not one of your 20? I think it is 40/60, that's your 1st term. I move on to B. What is the prob. that the number on B is not one of your 20? Why isn't this also 40/60?
I am slow to wrap my brain around this kind of problem so I try to be systematic.
oh because the marbles are not being replaced.
Okay. Joe is holding 20 marbles in his hand. The prob. that my 1st marble isn't one of them is 40/60.
Move on to my next marble. Joe still has 20 marbles in his hand. What is the prob. that my 2nd marble isn't one of Joe's 20?
Why isn't the answer the same?
well damn...now I am confused.
so you think it should be 1 - [(40/60)^20]? maybe that's it.
