Can i post a list of my homework problems
The discussion revolves around various physics homework problems, particularly focusing on concepts related to electric current, pressure in fluids, scaling of mass and strength, and Archimedes' Principle. Participants are seeking guidance on how to approach these problems without directly asking for solutions.
  • Exploratory, Conceptual clarification, Problem interpretation, Assumption checking
  • Participants discuss posting homework problems one at a time and sharing their attempts at solutions. Questions arise regarding the correct application of formulas, unit conversions, and the implications of scaling in physical problems.
Some participants have provided hints and clarifications regarding the use of equations and the relationships between physical quantities. There is an ongoing exploration of concepts, particularly in relation to volume, weight, and density, as well as the implications of experimental results in the context of Archimedes' Principle.
Participants are navigating the constraints of homework guidelines, which discourage direct answers but encourage hints and pointers. There is a focus on understanding underlying principles rather than simply solving problems.
Security
Can i post a list of my homework problems (not to get answers or anything) but to give me pointers on problems?
The thing to do is post the problems one at a time, showing what you've done so far in solving them. If you can't even begin, just tell us what you know and you may get some hints.
well...
well in my physics exams, i am on the last 3 subjects and then a finish high school. Right now I am am dealing with eletric current, flow of charge, ohm's law etc.. In my future exams, my last two, deal with eletric circuits, quantum physics, nuclear fission and fusion. and its giving me a headache (but keep in mind that this is conceptual physics, so they don't go too in-depth. but any hints or help, or even study habits that can help would be appreciated. And i really need to turn in these exams to finish high school. Thank You for reading.
For the basic electricity stuff, just make sure that the units work out. Volts is always J/C, Amperes is always C/s, Watts is always J/s, Ohm is always V/A. If you can just remember the units, it's easy as hell.
For the nuclear reaction part, make sure the mass and charge work out. If you seem to have too much mass, try adding negative mass like positrons.
can i do this...
how about i try and finish all my exams, and the ones I am not sure about, ill post the questions and tell you what i put down as the answer. Is that o.k.
Of course. Until you give us specific questions, we won't be able to help much. :smile:
I have a couple of question with one exam. But the first one goes like this:
A "deep" is the name given to any ocean area with a depth of more than 5,490 meters. What is the minimum water pressure (ignoring atmospheric pressure) at the bottom of an ocean deep? Show your calculations. (Note that the weight density of sea water is 10,100 N/m3.)
i put down pressure due to: liquid = weight density x depth
water pressure = 1031kg/m3 x 5,490 meters
meter pressure = 5,660,190
But that wasnt correct. Am I using the correct equation for this problem. Are there any hints that i can use?
You stated the equation correctly, but didn't plug in the right numbers:
Pressure = Weight density X depth
Well, what's the weight density? And what did you plug in? :wink:
10,1000 N/m3 x 5,490 meters = 55,449,000 ?
Looks OK to me. (Don't leave out the units when giving the answer.)
what units would be proper for this equation?
I got it. N/m2. correct?
Well moving on.
The Next problem is kind of hard for me, because i don't really understand volume and how it relates to mass, weight, etc.. But it goes like this:
An ant 2 cm long weighs .0003 Kg and can lift 10 times its weight, in addition to the weight of its own body (in other words, it can lift a total of .0033 kg.) Show your calculations for A, B, and C.
for the A question it asks -- If the ant were 100 times as large, how long would it be? I wrote : 2 cm x 100 = 200 cm, which was correct.
The second question asks -- How much would the giant ant weigh? I wrote .0003 kg x 100= .03 kg, which was incorrect
The second question asks -- How much could the giant ant lift? I wrote .03 x 100 = 3 kg
3 kg + .03 = 3.03kg, which was incorrect.
Teachers notes say: The ant would have an increase in weight proportional to its increase in volume for the 2nd question / Teacher says for the third question that The ant would have an increase in strength proportional to its increase in surface in surface area.
I don't understand volume or scaling enough to understand these hints or to do the problem, can you help?
Let's use an example to make it clearer. Consider three things: a stick of length L, a square of length L, and a box shaped like a cube with all sides with length L. Here are the relationships that matter:
Length (of stick) = L; Area (of square) = LxL; Volume (of cube) = LxLxL.
So what happens if I double the length---instead of L, I put 2L?
Length = 2L (it doubles); Area = 2L x 2L = 4L (it goes up by 2-squared); Volume = 2L x 2L x 2L = 8L (it goes up by 2-cubed).
These can be tricky. If someone asked me: "if the ant is 100 times larger, how long would it be?" I would have to ask what do you mean "larger"? Do you mean longer? (apparently they meant longer)
For example: if you say a guy is twice your size, do you mean twice as tall? or twice as heavy? Depends! (And it obviously makes a difference: a guy twice your height would most likely weigh a lot more that twice your weight.)
The weight and volume go together. So if the ant increased it's length by 100x; the volume would go up by 100x100x100= 1,000,000--and so would its weight. If the normal ant weighs 0.0003Kg; the giant ant would weigh 1,000,000 x 0.0003 = 300Kg!
Strength goes up with the area. (Imagine the cross-section of the muscles getting bigger.) So the ant would be 100x100 = 10,000x stronger. Thus if a normal ant could lift 0.003Kg, the super size ant could lift 10,000 x 0.003 = 30 Kg. (But his weight went up by a million times! The giant ant probably wouldn't be able to move, as he now weighs 300Kg!)
Make sense?
it makes sense, but why do you have to multiple 100 three times?
I get it. Thanks a lot. I have 3morequestions on this exam. The next one goes like this:
Archimedes was an ancient Greek philosopher. According to tradition, he discovered what has come to be called Archimedes' Principle in the course of trying to solve a dilemma posed to him by King Hiero of Syracuse. King Hiero had provided pure gold to a goldsmith to fashion him a crown. When the crown was finished, the king suspected that the goldsmith had substituted less costly and less dense silver for some of the gold and thus kept some of the gold for himself. The King asked Archimedes to analyze the crown and determine if this was indeed the case.
Archimedes asked for a mass of gold equal in weight to the mass of gold King Hiero had supplied the goldsmith. He then put the gold in a container, filled the container to the brim with water, and removed the gold.
'The first question says: What happened to the water level in the container when the gold was removed? Why?' I answered, "The water level in the container decreased because of displaced water when the gold was put into the container." which was correct.
Secondquestion says: Archimedes then took the crown fashioned by the goldsmith and carefully lowered it into the container of water. What should have happened to the water level if the crown had been made of pure gold.' I answered on my second try, "To the point that water would be displaced and would be equal to the mass of Gold" which was correct.
The third question says: When Archimedes lowered the crown into the container, the water overflowed. What did this indicate about the volume of the crown compared to the volume of the mass of gold? Did this prove or disprove that the goldsmith had cheated the King?Why?
Again I tried the second time and failed by saying, "This proved that the goldsmith was not cheating the king. The teacher put a hint asking to consider weight density = weight/volume. Is their a way that i can post a more questions the one at a time or is this the standard for doing this here?
It seems to me that since the crown will be denser than water and therefore does not float, regardless of whether it is made of silver or gold, then the amount of water displaced would be equal in volume to the crown, but not equal in mass.
If the crown and the piece of gold are of equivalent mass, then this proves that the crown is not made of pure gold. The fact that the water overflowed with the crown, and did not with the equivalent mass of gold, indicates that the crown is of larger volume and therefore lower in density. Gold is of higher density than silver, so it must be that it was made, in part, with silver.
But how does it being of higher density show that the goldsmith didnt cheat the king. my weak point in physics are volume and density.
Well, if it was of equivalent density it would show that the goldsmith didn't cheat the king.
Density is mass per unit volume.
ρ = m/V
For a given mass, m, as the density increases, the volume decreases.
Now, assuming that the crown and the lump of gold are the same mass, which the goldsmith could have made sure of with a balance, if the crown has a significant silver content then it will be of larger volume than the lump of gold because silver is less dense than gold i.e. it needs to occupy a larger volume to be of the same mass.
So, both the crown and the gold will displace an amount of water equivalent to their respective volumes. The gold will be less voluminous than the crown if the crown is not pure gold. Therefore, when the crown is placed in the water, the water level will rise higher than the water level with the gold in the water if the crown is not pure gold.
Am I making sense?
Here is how I would solve this:
N/m^3 is the same as pascals/m
10100 N/m^3 = 10100 Pa/m
Since I have a rate for perssure and I have a depth, just multiply.
10100 Pa/m * 5490 m = 55449000 Pa
Huge pressure :D
Your teacher is full of s***. You said that your size was correct, 200cm. If you only double one dimension, the mass is doubled. If you double two dimensions, the mass is 4x. If you double three dimension, the mass is 8x.
Lets look at some numbers. Let's say I have a box that is 1m x 1m x 1m and has a density of 5kg/m^3. My initial volume is just 1*1*1 which is 1m^3. Multiply the density by the volume to get a mass of 5kg. Ok now let's say I double the length of 1 side on this box. Now my size is 2m x 1m x 1m = 2m^3. Multiply the volume by the density, 2*5, and you get 10kg. One dimension of the box was doubled, thus, the volume doubled, thus, the mass doubled. Since you only changed one dimension and you verified that it was correct, you only need to multiply the mass by 100 which means you are right and your teacher is an idiot.
