What is the Van't Hoff factor for NaCl in seawater?
The discussion revolves around the calculation of the Van't Hoff factor for NaCl in seawater, focusing on the relationship between vapor pressure, mole fraction, and molality. Participants explore the implications of NaCl's dissociation in solution and how it affects concentration calculations.
  • Homework-related
  • One participant presents calculations for the vapor pressure of seawater and attempts to derive the concentration of NaCl in molality, arriving at a value of 1.88 m.
  • Another participant confirms the dissolution of NaCl into its constituent ions, Na+ and Cl-.
  • A participant expresses uncertainty about how to proceed after calculating the mole fraction of water and NaCl, indicating a need for further assistance.
  • One participant questions the conversion from molar fraction to molality, suggesting that the strong electrolyte nature of NaCl and its complete ionization may influence the calculations.
  • A later reply prompts checking the definition of the Van't Hoff factor, implying its relevance to the discussion.
Participants do not reach a consensus on the correct molality of NaCl, with one participant asserting a value of 1.88 m while a textbook states it as 0.920 m. The discussion reflects multiple competing views regarding the calculations and the role of the Van't Hoff factor.
The discussion highlights potential limitations in the calculations, including assumptions about the complete dissociation of NaCl and the definitions used for molality and mole fraction. There are unresolved mathematical steps that could affect the final results.
amcavoy
At 25oC the vapor pressure of pure water is 23.76 mmHg and that of seawater is 22.98 mmHg. Assuming that seawater contains only NaCl, estimate its concentration in molality units.
[tex]X_1=\frac{n_1}{n_1+n_2}\implies n_2=\frac{n_1-X_1n_1}{X_1}[/tex]
where n1 is the moles of solvent and n2 is the moles of solute.
[tex]22.98=X_1\left(23.76\right)\implies X_1=.9672[/tex]
and 1000 g of water is equal to 55.49 mol (n1), so plugging this all in gives:
[tex]n_2=1.88\text{mol}[/tex]
which would be the same as the molarity.
However, my textbook says that the molarity is .920 m. Where did I go wrong? Thanks a lot.
NaCl is dissolved.
Right, Na++Cl-->NaCl.
Thanks for the help.
Can someone please explain this to me, because I'm not quite sure how to solve this problem. I only reached the part where I got the mole fraction of water and NaCl, but that's just it. I don't know what to do next. Help would be greatly appreciated. :(
You mean you have no idea how to convert molar fraction to molality?
Okay, I found out how to convert it molality, but I keep getting 1.88 m not .920 m. How does the strong electrolyte/complete ionization of NaCl make a difference?
Check what Van't Hoff factor is.
