Proving 2^(2^n) - 6 is a Multiple of 10: Mathematical Induction Method
The discussion revolves around proving that for every natural number n ≥ 2, the expression 2^(2^n) - 6 is a multiple of 10 using the method of mathematical induction. Participants explore the steps involved in the proof and share hints and suggestions for approaching the problem.
  • Homework-related
  • One participant expresses confusion about how to start the proof and questions the relevance of series.
  • Hints are provided regarding the relationship 2^(2^(n+1)) = (2^(2^n))^2, which some participants find helpful for their understanding.
  • Another participant suggests that if they can show 10*n ≤ 2^(2^n) - 6, it might help in proving the statement, although they express uncertainty about the correctness of this approach.
  • One participant outlines the steps of mathematical induction, emphasizing the need to assume P_k is true and to prove it for P_(k+1).
  • There is a suggestion to focus on the fact that if M - 6 is a multiple of 10, then M must end in the digit 6.
  • Concerns are raised about the use of inequalities in the proof, with a participant noting that only the condition n ≥ 2 should be specified.
  • Another participant summarizes the steps of mathematical induction and encourages others to use the hints provided to complete the proof.
  • Expressions of gratitude are shared among participants for the assistance received in navigating the problem.
Participants do not reach a consensus on the best approach to prove the statement, and multiple viewpoints and methods are presented throughout the discussion.
Some participants express confusion about the application of inequalities in their reasoning, and there are unresolved questions about the validity of certain approaches to the proof.
dglee
Show taht for every natural numbers n>=2 [tex]n \geq 2[/tex] the number 2^2^n - 6 [tex]2^{2^n} -6[/tex] is a multiple of 10. Using mathematical induction.
Okay i got no clue how to start this question. Ahhh Is there a series where the x^n is a series? Well this stuff really sucks.
HINT:
[tex]2^{2^{n+1}} = \left( 2^{2^n}\right)^2[/tex]
Tide said:
HINT:
Oh WOw... that helped a lot.. now i can show that its inductive hmm but how would i show its a multiple of 10?
hmm maybe if i said 10^2 is 100 so that's a multiple of 10. [tex]10*n\leq2^{2^n}-6[/tex] if i proved that.. hmm i wonder if that would be right... [tex]10*(n+1)\leq2^{2^(n+1)}[/tex] hmm if i proved that would i have solved the question?
wow if hmm well ahaha thanks a LOT! YOUR AWSOME. that little hint helped a lot but i got no clue if I am actually doing it right.
For Mathematical Induction, you assume that P_{k} is true, in this case for n greater or equal to 2. With this, you can immediately say that 2^(2^k) - 6 is equal to 10a, for some a, where a is a positive integer.
Can you then use this fact, and the hint provided, to prove the desired result for 2^(2^(k+1)) - 6?
hmm should could i say that
[tex]10(a+x)\leq (\left2^{2^n}\right )^2 - 6[/tex] where x is some positive number and should that it is inductive to prove that 10 is a multiple?
soo
[tex]10(a)\leq2^{2^n} - 6[/tex] then
[tex]10(a+x)\leq(\left 2^{2^n}\right)^2 - 6[/tex]
then show that
[tex]10(a+x)\leq2^{2^{n+1}} -6[/tex] ahhh I am confusd now.. ahh
HINT: If M - 6 is a multiple of 10 then M ends in the digit 6! :)
Hmmm... Why are there so many inequalitites in your working? From what I know, the only inequality to appear in your solution should be the fact that n is greater than or equal to 2, but this is just a specification, and should not appear in your proof.
Steps in Mathematical Induction
1) Let [tex]P_{n}[/tex] be the statement [tex]2^{2^n}-6[/tex] is divisible by 10, for n[tex]\geq[/tex] 2.
2) Check that the result you want to prove is valid for n=2, so [tex]P_{2}[/tex] is true.
3) Assume [tex]P_{k}[/tex] is true, for some n [tex]\geq[/tex] 2. So, [tex]2^{2^k}-6[/tex] = 10a, for some a, which is a positive integer.
4) Using this result, you must somehow prove that [tex]2^{2^{k+1}}-6[/tex] is a multiple of 10. How would you go around doing it? Look at the first hint provided and observe... What has been done to the term [tex]2^{2^n}[/tex] ? USE BOTH THE RESULT FROM STEP 3 AND THE FIRST HINT
5) Once you have proven step 4, give a conclusion. "Since [tex]P_{2}[/tex] is true, and for some n[tex]\geq[/tex]2, [tex]P_{k}[/tex] is true [tex]\Longrightarrow[/tex] [tex]P_{k+1}[/tex] is true. By Mathematical Induction, [tex]P_{n}[/tex] is true for all n[tex]\geq[/tex]2."
Wow thanks a lot for your help. I will try to figure this out. You helped a lot pizzasky and Tide. :smile:
