Ap physics rolling/slipping billiard ball
The discussion focuses on the physics of a billiard ball transitioning from sliding to rolling without slipping. Key parameters include the ball's mass (M), radius (R), and moment of inertia (Ic = 2/5MR²). The expressions for linear velocity (v) and angular velocity (ω) as functions of time during rolling without slipping are central to solving the problem. The concept of "rolling without slipping" is defined mathematically, emphasizing that once this condition is met, the acceleration becomes zero.
  • Understanding of rotational dynamics and moment of inertia
  • Familiarity with the concept of linear and angular velocity
  • Knowledge of friction and its role in motion
  • Basic principles of kinematics
  • Develop equations for linear velocity of a rolling object
  • Explore the relationship between angular momentum and frictional forces
  • Study the conditions for rolling without slipping in detail
  • Investigate the effects of different coefficients of friction on motion
Physics students, educators, and anyone interested in understanding the dynamics of rolling motion and friction in classical mechanics.
Schmoozer3348
A billiard ball has mass M, radius R and moment of inertia about the center of mass Ic=2/5MR^2. The ball is struck by a cue stick along a horiontal line through the ball's center of mass so that the ball initially slides with a velocity Vo. As the ball moves across the table (which has a coefficient of sliding friction U ), its motion gradually changes from pure translation through slipping to rolling without slipping.
a)Develop an expression for linear velocity v of the center of the ball as a function of time while it is rolling without slipping
b)develop an expression for the angular velocity w of the ball as a function of time while it is rolling without slipping.
c)determine the time at which the ball begins to roll without slipping.
d) when the ball is struck it acquires an angular momentum about a fixed point P on the surface of the table. During the subsequent motion, the angular momentum about P remains constant despite the frictional force. Explain why it is so.
I'm stuck on the first part but am confident i could figure out b,c, and d if i had a little help with a. Is it kinematics V=Vi+at?
Pretend the ball was suspended in mid-air. If it's spinning at a certain angular speed, how fast is its surface moving (linear speed) with respect to the center? Got it? Now if I want to place this spinning ball on the ground so that the surface doesn't slide, how fast had it better be moving?
This kind of thing should be in the Homework Help forums, but now that we've started...
The purpose of part a is for you to define --mathematically-- the conditions for "rolling without slipping". It's got nothing to do with kinematics (except trivially) since once the ball rolls without slipping, acceleration is zero.
Try this way of thinking. For a rotating ball, what's the speed of surface with respect to the center? Then, of course, the translational speed of the ball is the speed of the center with respect to the ground. Now combine these to find the speed of the ball surface where it touches the ground with respect to the ground. "Rolling without slipping" means that that speed (surface of ball with respect to the ground) is zero.
  • · Replies 60 ·
  • · Replies 42 ·
  • · Replies 21 ·
