How Can a Researcher Correctly Prepare Ba3(PO4)2 Instead of Ba(HPO4)?
  • Thread starter Thread starter Soaring Crane
    Preparation
The discussion focuses on the preparation of barium phosphate (Ba3(PO4)2) instead of barium hydrogen phosphate (Ba(HPO4)). The correct reaction requires a stoichiometric ratio of 3:2 for barium chloride (BaCl2) and ammonium hydrogen phosphate ((NH4)2HPO4), respectively. The desired reaction is represented as 3BaCl2 + 2(NH4)2HPO4 --> Ba3(PO4)2 + 4NH4Cl + 2HCl. The researcher must adjust the molarity and volume of the reactants to achieve the correct stoichiometry, and consider the acidity of the solution to prevent the formation of Ba(HPO4).
  • Understanding of stoichiometry in chemical reactions
  • Knowledge of barium chloride (BaCl2) and ammonium hydrogen phosphate ((NH4)2HPO4)
  • Familiarity with the concept of molarity (M) in solution preparation
  • Basic principles of solubility and precipitation reactions
  • Research the solubility characteristics of Ba3(PO4)2 and Ba(HPO4) in different pH conditions
  • Learn about adjusting molarity and volume in chemical reactions for desired outcomes
  • Explore methods to control acidity in chemical solutions to influence precipitation
  • Investigate alternative synthesis routes for barium phosphate compounds
Chemical researchers, laboratory technicians, and students studying inorganic chemistry who are involved in compound synthesis and reaction optimization.
Soaring Crane
Suppose there is a researcher at a chemical company whose job is to create the compound barium phosphate. BaCl2*2H2O and (NH4)2HPO4 was mixed together in a water solution. However the compound that formed was not the desired Ba3(PO4)2 but Ba(HPO4).
How can the researcher prepare the correct solution?
Wanted reaction: 3BaCl2 + 2(NH4)2HPO4 --> Ba3(PO4)2 + 4NH4Cl + 2HCl
Reaction in reality: BaCl2 + (NH4)2HPO4 --> Ba(HPO4) + 2NH4Cl
Well, there would need to be a 3:2 ration of barium chloride and phosphate compound instead of 1:1.
If there is a set M of 0.6 M for each reactant, the vol (L) can be changed so 5 L of BaCl2 yields 3 mol and 3.33 L of (NH4)2HPO4 yields 2 mol?? Are there other ways (changing M) to achieve the desired results?
Thanks.
try thinking about the reverse reaction, the differences in the condition of dissolution of Ba3(PO4)2 and that of Ba(HPO4) is simply that the first is done in an more acidic solution (that probably means that it's less soluble than the amphoteric salt). PO4 3- is being consumed by the acidic solution, to HPO42-. Assuming that Ba(HPO4) is also slightly insoluble, then it will now precipitate.
11K
9K
