Solve Astronomy Problems: Tips & Formulas
  • Thread starter Thread starter astronomystudent
    Astronomy
This discussion focuses on solving various astronomy problems, including calculating the diameter of Mars, the focal length of the Meade 12 inch LX200 telescope, the rotation period of Io, the density of a Kuiper object, and the weight on a hypothetical planet. Key formulas and concepts such as arcseconds, focal ratios, and resonance are essential for these calculations. Participants emphasize the importance of showing working steps and understanding the underlying principles to receive effective help.
  • Understanding of arcseconds and astronomical measurements
  • Familiarity with focal length calculations and f-stop ratios
  • Knowledge of celestial mechanics, including resonance and orbital parameters
  • Basic principles of density and mass calculations in astrophysics
  • Study the formula for calculating the diameter of celestial bodies using angular size and distance
  • Learn about the properties and calculations related to telescope optics, specifically for the Meade 12 inch LX200
  • Research the concept of orbital resonance and its implications for moons and planets
  • Explore density calculations for celestial objects and their significance in astrophysics
Astronomy students, educators, and enthusiasts seeking to deepen their understanding of celestial mechanics, telescope optics, and density calculations in astrophysics.
astronomystudent
Astronomy Problems: Please Help!
I don't even know how to begin these problems. If someone could leave me tips or formulas or anything to help me solve these it would be greatly appreciated. Here are the following:
1. What is the diameter (in Kilometers) of Mars if it appears 18 arcsec in sized when it is 0.520 AU from Earth?
2. What is the focal length of the Meade 12 inch LX200 (12 inch x 25.4 mm/inch aperture) when it is used at f/5.86? How would a 15 sec exposure at f/5.86 compare to an exposure at f/20? What would be the pixel resolution for a 9 micron pixel at f/5.86?
3. What is the rotation period of Io (in days) if it is in a 1:1 resonance with Jupiter like our Moon is with Earth. Jupiter has a mass of 318 M(earth). Io's mass is insignificant and it has a semimajor axis of 421,600 Km. Remember you must use EMDs and lunar sidereal months with Earth masses or change to Solar masses, years and AUs!
4. If the diameter of a new Kuiper object was found to be 1/10th the diameter of Earth and its mass was 1/3000th of Earth, what would its density be (in g/cc or kg/m^3).
5. If a new asteroid has a period of exactly one year, but an eccentricity of 0.25, wherer are the aphelion and perihelion points (in AU).
6. What woul be your weight on a planet with a mass of 5.67 times the mass of the Earth and a radius of 13,456 km? What would be the density of this planet?
if I don't say it, someone else will... it'll really help your chances of getting helpful responses on these forums if you show at least some working or at least describe which parts it is that you don't understand, for instance; you're asking for formulas, but surely your lecture notes contain most things you need to know?
(i'll be on later and i'll give some of those questions a bash, seems like level 1 undergrad to me?)
  • · Replies 21 ·
