How Do You Calculate the Initial Pressure in an Air Rifle Using Thermodynamics?
The discussion revolves around calculating the initial pressure in an air rifle using thermodynamic principles, specifically focusing on an adiabatic process involving an ideal gas. The original poster describes the setup, including the dimensions of the air rifle, the mass of the pellet, and its exit speed.
  • Participants explore the relationship between initial and final pressures and volumes using the adiabatic process equations. Questions are raised about how to determine the final volume and pressure, as well as the implications of the pellet's acceleration and the forces involved.
The discussion is ongoing, with participants providing insights into the relationships between momentum, force, and pressure. Some guidance has been offered regarding the equations involved, but no consensus has been reached on the specific values needed for the calculations.
Participants note constraints such as the need for additional information regarding the acceleration of the pellet and the time taken to reach its final speed. The initial volume and dimensions of the barrel are provided, but the final volume and pressure remain uncertain.
thenewbosco
an air rifle shoots a lead pellet by allowing high pressure gas to expand.
This happens quickly so it is an adiabatic process. initially 12 cubic centimeters of air are admitted to the barrel. It behaves as an ideal gas, [tex]\gamma = 1.40[/tex]. The air expands behind a 1.1 g pellet and pushes on it as a piston with cross sectional area 0.03 cm^2. the pellet emerges from the barrel with speed 120 m/s.
I am to use the work gone by the gas:
[tex]W = (\frac{1}{\gamma - 1})(PiVi - PfVf)[/tex]
to calculate the initial pressure required.
I do not know though how to find the final volume and final pressure...
I thought to use [tex]PfVf^\gamma = PiVi^\gamma[/tex] but this does not seem to change anything for me i still need to know Vf...
any help on this...thanks
Can you relate the time rate of change of momentum of the pellet to the average force exerted on it? And who would exert it (rather what)?
Also while deriving the equation for work done in an adiabatic process, you have already taken into account that [itex]P_{i}V_{i}^{\gamma} = P_{f}V_{f}^{\gamma}[/itex].
Hold on a sec: you know the mass of the pellet, its initial and final speeds so you can calculate the the change in momentum. To calculate the force, you need to find the rate of change of momentum. You need either the acceleration of the pellet or the time it took to attain a speed of 120 m/s. I think something is missing here. But if I get some more ideas, I'll post them here soon.
Bosco, you have 2 equations in 2 unknowns. What's the problem ?
what is the distance for which the bullet was accelerated?
oh i forgot the distance is 50cm.
so what's the change in volume?
i said that it was 12cm^3 (the initial volume admitted) + (0.03cm^2)(50)cm.
I would then put this into the Vf for final volume but i then need the final pressure which i don't know...
anybody?
just use substitution, right?
bosco,
I've merged your two threads together. Don't post the exact same thread multiple times. Once is enough.
  • · Replies 22 ·
15K
  • · Replies 69 ·
