Finding Tension in Multibody Systems in AP Physics II
The discussion revolves around finding tension in multibody systems within the context of classical mechanics, specifically in AP Physics II. Participants are exploring how to determine the appropriate mass to use when calculating forces such as tension between objects.
  • Participants discuss the criteria for using individual versus combined masses when calculating tension in a rope between two objects. Questions arise about whether to analyze the system as a whole or as separate entities.
Some guidance has been offered regarding the analysis of forces acting on individual objects versus the entire system. Participants are considering different approaches to understanding the relationships between forces and masses, but no consensus has been reached on a definitive method.
There is an ongoing exploration of Newton's laws and how they apply to internal versus external forces in multibody systems. Participants express uncertainty about general rules for analyzing such problems.
z-component
We're now studying classical mechanics in AP Physics II (forces specifically) and I have a very broad question. When I'm given a multibody system and am asked to find specific forces, such as tension between two objects, I sometimes use the wrong value for mass. How do I know if I am supposed to add two masses or just use the one object's mass depending on what's asked?
For example, if I am to find the tension in a rope between two objects, do I use the mass of the two objects or of the whole system?
It depends on what you are trying to find. If you are trying to find a property of the entire system (say the acceleration of the center of mass), then you'd use the mass of the entire system.
In this case, the only way to find the tension is by analyzing the masses separately. (If you treat them as a single system, the tension will be an unknown internal force.)
So if I'm finding tension or normal forces between two objects I analyze separately as in two different equations? Is there any general rule of thumb for these situations?
Don't think of this as an additional "rule of thumb" that you have to memorize. It's just the way Newton's laws work. If you want to study the forces acting on a given object (like the tension or normal forces you mentioned), then apply Newton's 2nd law to that object.
Realize that if you take both objects together as a single system, you won't be able to learn anything about the forces between them, since they will be internal forces (and, per Newton's 3rd law, they will cancel out). This will all become obvious after you've solved a few hundred problems. :smile:
But, as I said earlier, often it will prove useful to analyze the problem both ways: As a composite system and as separate objects.
Thank you, that helps. I am looking forward to the 100th time I solve a mechanics problem... ;)
  • · Replies 22 ·
  • · Replies 39 ·
  • · Replies 38 ·
  • · Replies 62 ·
  • · Replies 22 ·
  • · Replies 28 ·
