Calculating Number of Folders: 4^4 + 4^3 + 4^2 + 4^1
  • Thread starter Thread starter WarrickF
The discussion centers on calculating the total number of folders created in a hierarchical structure using the formula 4^4 + 4^3 + 4^2 + 4^1, where 4 represents the number of folders at each level and the exponent indicates the depth of levels. The user seeks a generalized formula for any number of levels and folders, specifically mentioning the need for implementation in Excel or Open Office. The mathematical concept of a geometric series is introduced as a solution, with the formula provided as \(\sum_{i=0}^{n}r^i=\frac{1-r^{n+1}}{1-r}\) for calculating the total number of folders.
  • Understanding of geometric series and their properties
  • Basic proficiency in Excel or Open Office for formula implementation
  • Familiarity with exponentiation and its applications in combinatorial calculations
  • Knowledge of mathematical notation and summation
  • Research how to implement geometric series formulas in Excel
  • Learn about recursive functions for calculating folder structures programmatically
  • Explore advanced Excel functions like SUMPRODUCT for complex calculations
  • Investigate the use of Open Office Calc for similar mathematical operations
This discussion is beneficial for mathematicians, software developers, and data analysts who need to calculate hierarchical structures or optimize folder organization in spreadsheet applications.
WarrickF
Hi All,
Quick disclaimer – I'm no math genius ;)
I have written a quick script that take as it's input the number of levels you'd like to iterate and the number of folders at each level you'd like to create.
So you have 4 base folders, in each folder you have 4 more folders etc. 4 levels deep.
The math to calculate how many folders there are at the end of the day looks something like this:
I can do this math manually, but I have no idea how to create a formula that allows me to plug in any number. Let's say I wanted to go 12 levels deep .. how many folders would I end up with? I can do this manually of course, but then I would learn nothing and run into the same problem a yeaqr from now when I need to do the same math with 1000 folders ;)
I'm trying to do this in Excel \ Open Office so any formula references you can give would also be greatly appreciated.
Thanks
Warrick
it's a geometric series:
[tex]\sum_{i=0}^{n}r^i=\frac{1-r^{n+1}}{1-r}[/tex]
(r not equal to 1)
10K
  • · Replies 24 ·
  • · Replies 34 ·
9K
