Second order differential equations
The discussion centers on solving first-order differential equations, specifically the equation dy/dx - 2y = e^(5x). The user correctly applies the integrating factor method, resulting in the general solution y = 1/3e^(5x) + Ce^(2x). Additionally, the user explores the chain rule for finding dz/dt and dz/dx for given functions, demonstrating the application of partial derivatives and substitution. A correction is noted regarding the factor of 2 in the derivative of sin(2y).
  • Understanding of first-order differential equations
  • Familiarity with integrating factors in differential equations
  • Knowledge of chain rule in calculus
  • Ability to differentiate composite functions
  • Study the method of integrating factors for first-order linear differential equations
  • Learn about higher-order differential equations and their solutions
  • Explore the application of the chain rule in multivariable calculus
  • Investigate the use of partial derivatives in physics and engineering problems
Students and professionals in mathematics, engineering, and physics who are working with differential equations and calculus concepts, particularly those focusing on first-order equations and chain rule applications.
dagg3r
hi guys need some help on diff eqn, I've done the workingout
and answers but not sure if they are right mind if someone
can check them for me thanks
Find the general solution of the differential equation
dy/dx - 2y = e^(5x)
i found I(x) = e^ integral (-2 dx) = e^(-2x)
as I(x) = e^Integral (p(x)) in this case p=-2
therfore d/dx((e^-2x)*y) = e^(3x) // as we multiply both sides by e^(-2x)
therefore e^(-2x)y = integral e^(3x)
e^(-2x)y = e^(3x)/3 + C
y= e^(3x)/(3*e^(-2x)) + C
y= 1/3e^(5x) + Ce^(2x)
2.
given that z=2xt^3 - cos5x and x^3 + t^2 = 6x
find dz/dt using a chain rule
i will use notatio 9 as the "day symbol"
dz/dt = 9z/9x*dx/dt + dz/dt
= (2t^3 + 5sin5x)*dx/dt + 6xt^2 !(3)!
then knowing
x^3 + t^2 = 6x i diff resp to x so
3x^2*dx/dt - 6dx/dt = -2t
dx/dt = 2t/(3x^2 - 6)
i subtituted this back into (3) and got
= (4t^4 + 10tsin5x + 18x^3t^2 - 36xt^2) / (3x^2-6)
3. given that z=e^(5x)sin2y and y=x^2 + 5
find dz/dx as a function of x using a chain rule
same 9 symbol represtn day
dz/dx=9z/9x + 9z/9y*dy\dx
dz/dx = 5e^(5x)sin2y + 2xe^(5x)cos2y
i subtitued y=x^2 + 5 and got this
dx/dx = e^(5x) * [5sin(2x^2+10) + 2xcos(2x^2 + 10) ]
so i hope i did it right
thanks for the help guys
dy/dx - 2y = e^(5x)
Yes, that's correct.
2.
then knowing
I think that's right but my feeling is you would be better off leaving it as 6xt^2-(4t^4+ 5sin5x)/(3x^2-6)
You are missing a factor of 2: The derivative of sin 2y wrt y is 2 cos2y and the derivative of x^2+ 5 is 2x: that should be 4x cos(2x^2+ 10).
Was there a reason for titling this thread "second order differential equations"? There was only one differential equation and it was first order.
  • · Replies 25 ·
  • · Replies 18 ·
