Velocity vector's change of direction
The discussion focuses on the behavior of velocity and acceleration vectors when an object's direction changes without a change in speed. It establishes that while the magnitude of the velocity vector remains constant, its direction can change, leading to a perpendicular relationship between the velocity and acceleration vectors. The key formulas presented are v = r / time for velocity and a = d v / dt for acceleration, emphasizing that these are vector quantities and that the direction of acceleration aligns with the change in velocity.
  • Understanding of vector quantities in physics
  • Familiarity with basic kinematics
  • Knowledge of calculus, specifically derivatives
  • Concept of displacement vector
  • Study vector calculus to deepen understanding of vector derivatives
  • Explore the relationship between velocity and acceleration in circular motion
  • Learn about the implications of perpendicular vectors in physics
  • Investigate real-world applications of velocity and acceleration vectors in engineering
Students of physics, educators teaching kinematics, and professionals in engineering fields who require a solid understanding of vector dynamics.
boris16
hi
If an object changes it's direction but not speed, then velocity vector will only change its direction but not magnitude.
* ... delta
*r... displacement vector
Formula for velocity change is *v = *r / *time
This formula doesn't tell us anything about the direction of *v, it tells us
only about its magnitude ?
Same could be said for acceleration vector a. Formula will only tell you acceleration vector's magnitude, but not it's direction ( well we do know the direction is same as *v, but since we don't know the direction of *v it's of little use ) ?
bye
The correct "formulas" are
[tex]\vec v = \frac {d \vec r}{dt}[/tex]
[tex]\vec a = \frac {d \vec v}{dt}[/tex]
These are vector quantities. If the direction of the velocity changes without changing the speed, the velocity and acceleration are perpendicular to each other.
  • · Replies 48 ·
  • · Replies 37 ·
