Can Photons Really Split into Multiple Photons?
  • Context: Graduate
  • Thread starter Thread starter professor
    Photon Splitting
The discussion revolves around the concept of photons splitting into multiple photons, particularly in the context of energy conservation and the mechanisms involved. It explores theoretical and experimental aspects, including nonlinear optics and specific processes like parametric down-conversion (PDC).
  • One participant questions the mechanics of photon splitting, seeking clarification on transformation equations and the implications of massless photons.
  • Another participant explains that photon energy can be split through nonlinear optics, specifically via parametric down-conversion, involving conservation of energy and momentum.
  • A later reply asserts that PDC cannot occur with free-space photons, as it requires interaction with bound electrons in a nonlinear medium.
  • Another participant suggests that while a lone photon in free space could theoretically split into three real photons while conserving energy and momentum, this does not occur due to the nature of photons as bosons and their behavior as field waves.
Participants express differing views on whether photon splitting can occur in free space, with some asserting it is not possible while others propose theoretical scenarios where it could happen. The discussion remains unresolved regarding the conditions under which photon splitting might occur.
The discussion highlights limitations in understanding the specific conditions required for photon splitting, including the need for nonlinear media and the implications of photon behavior as bosons.
professor
photon "splitting"
I have heard a thing or two about photons splitting into more photons and dividing the original energy amongst themselves, but have never really heard it explained. I suppose it should work out just fine with photons having no mass, but just te be sure, is there some transformation equation that accounts for this (for instance if you put in one with 1 initial charge, and then it comes out as 2 each with half of the initial, or is it a bit more complex than that... seems a bit too simple in an area generally dealing with so many tensors and vectors i don't know what do do with myself.
Science news on Phys.org
The energy of a single photon can be split via intermediatory processes using nonlinear optics. The process as a whole is called parametric down-conversion and devices that perform this process are called Optical Parametric Oscillators (OPOs). Parametric down-conversion is a three-photon interaction between the pump, the signal (which is the wavelength we want to generate) and the idler, so by conservation of energy;
w_pump = w_signal + w_idler (Where w denotes angular frequency).
Obviously there are many combinations of w_signal and w_idler, however there is an additional constraint, namely conservation of momentum.
k_pump = k_signal + k_idler (Where k denotes the wave-vector).
This is otherwise known as the phase-matching condition. The frequencies that satisfy these equations will be the ones that are generated in significant amounts.
The photon energy can be 'split' in this way because the response of the atom to an applied Em field becomes nonlinear at high intensities, meaning additional frequency components are generated. Parametric down-conversion is actually the reverse process of another well-known nonlinear process - Sum-frequency generation.
Entire textbook chapters are devoted to this topic, I have done my best to summarise the important points, googling some terms mentioned above may yield more information, alternatively you can post more questions and I will do my best to answer them.
Claude.
P.S. For some reason, latex was not working, hence the typed equations.
Can this type of "split" occur with a free-space photon? No.
PDC is an interactive function of a photon with a bound electron.
thanks both- pallidins footnote helped me put this to a more specific image
PDC requires a non-linear medium in order to control the outcome.
But a lone photon in free space could split into 3 real photons
yet conserve Energy, momentum, and angular momentum (spin).
Because photons are bosons, the reason that they do NOT do it
must come from their size - they travel as field waves, not particles.
  • · Replies 19 ·
  • · Replies 0 ·
  • · Replies 19 ·
  • · Replies 29 ·
  • · Replies 19 ·
  • · Replies 18 ·
  • · Replies 32 ·
  • · Replies 108 ·
12K
