Did i add up these Ressitors right?
  • Thread starter Thread starter mr_coffee
The discussion focuses on calculating current and potential difference in a circuit involving an ideal battery with a voltage of 12.0 V, an ammeter resistance of 2.00 ohms, and a voltmeter resistance of 268 ohms. The user attempted to apply a previously successful method to a new problem but encountered difficulties. Key calculations involve determining the current through the resistor (R = 93.0 ohms) and the readings on the ammeter and voltmeter based on the total current and resistance relationships.
  • Understanding of Ohm's Law and its application in circuit analysis
  • Familiarity with series and parallel circuit configurations
  • Knowledge of how to calculate current and voltage readings in electrical circuits
  • Basic proficiency in using electrical measurement tools like ammeters and voltmeters
  • Study the principles of series and parallel circuits in detail
  • Learn how to apply Kirchhoff's laws for circuit analysis
  • Explore the impact of meter resistance on circuit measurements
  • Investigate advanced techniques for calculating equivalent resistance in complex circuits
Students and professionals in electrical engineering, circuit designers, and anyone involved in practical electronics who need to understand current and voltage measurements in circuits.
mr_coffee
Hello everyone, I'm suppose to find the current and potential difference, I did a smilar problem to this that Chi helped me on, and it worked out, i applied the same method but didn't work out right. Here is the question and under it is my work:
Question:
the ammeter and voltmeter resistances are 2.00 and 268 , respectively. Take E= 12.0 V for the ideal battery and R0 = 119 .
Picutre of Figure b: http://www.webassign.net/hrw/28-40b.gif
(a) If R = 93.0 what will the meters read for the two different connections (Figs. 28-40b)?
Figure B:
I = ?A
Potential Difference = ? V
work:
http://img463.imageshack.us/img463/111/lastscan8fp.jpg
Thanks!
I only see one connection which is the one in our drawing. anyway, it looks like you pretty much solved it! You know the total I so you just have to find how much of it goes through the R and A (call that I1), and how much goes through V (I2, I1+I2 = I, remember that the I and resistance are inversly related). I1 would be the reading for the ammeter, and I1 times the total resistance of A and R is the reading for the voltmeter.
9K
