Trig equations losing solutions
  • Thread starter Thread starter GregA
    Trig
The discussion centers on solving the trigonometric equation 7cos(x) + 6sin(x) = 2 within the interval of 0 to 360 degrees. The user initially employed the method of r*sin(x+y) with r = sqrt(85) and y = 49.4 degrees, leading to a solution of x + 49.4 degrees = +/- 12.53 degrees. This resulted in the correct solution of 323.1 degrees and an incorrect solution of 118.1 degrees, which was identified as a 180-degree rotation of the correct answer. The user seeks clarification on the appropriate method to use for such equations, noting the importance of the signs of sine and cosine in determining valid solutions.
  • Understanding of trigonometric identities and equations
  • Familiarity with the unit circle and angle measurements in degrees
  • Knowledge of the sine and cosine functions and their properties
  • Experience with solving equations involving multiple trigonometric functions
  • Study the application of the sine and cosine addition formulas in solving trigonometric equations
  • Learn about the implications of the signs of sine and cosine in different quadrants
  • Explore the use of trigonometric identities to simplify complex equations
  • Practice solving a variety of trigonometric equations to reinforce understanding of solution methods
Students studying trigonometry, educators teaching trigonometric equations, and anyone seeking to improve their problem-solving skills in trigonometric contexts.
GregA
one of the questions is as follows:
7cosx +6sinx =2...the answer is required between 0 and 360 degrees.
I first tried to tackle it using rsin(x+y) giving rsiny = 7, rcosy = 6...
r = sqrt(85), y =49.4deg
sqrt85sin(x + 49.4deg) = 2...sin(x + 49.4deg) =2/sqrt85...
x + 49.4deg =+/- 12.53deg
this gives rise to 323.deg and 298.1deg...of which only 323.1deg is correct, the other answer is 118.1deg but I got this by checking the answers, scratching my head for a while and then using rcos(x-y) with just the positive square root of 85.
the book doesn't state which expression should be used and a different book implies that all of the 4 expressions will yield the same result in all situations...my question is how should I know which expression to use or is there something wrong with my working? (I do know with hindsight that the above question requires the cosine of x to be positive if the sine is negative and vice-versa)
(I also have noticed that the wrong answer I got is a rotation about 180deg of the correct answer...but I am sure that this is not the way I should be arriving at a solution)
i'm thinking maybe you could use trig identities? i think i may have seen one like it in my textbook but i was never very good with trig!
meh!...didn't subtract 12.53deg from 180deg :biggrin: hit me like a hammer driving back home...and could only get back to the computer now
  • · Replies 20 ·
