Maximum possible static friction
The discussion revolves around the concept of maximum possible static friction between a body and a surface, specifically questioning the relationship between the coefficient of static friction and the normal force. Participants are exploring the conditions under which an object begins to move when a force is applied.
  • The original poster attempts to clarify whether maximum static friction is equal to or less than the product of the coefficient of static friction and the normal force. They express confusion over conflicting information found in various articles regarding the conditions for motion initiation.
  • Some participants discuss the nature of static friction, noting that it can vary and is not always at its maximum value unless a specific threshold is met.
The conversation is ongoing, with participants sharing insights about the nature of static friction and its relationship to applied forces. There is recognition of the nuances involved in understanding when an object begins to move, but no explicit consensus has been reached.
Participants are grappling with the implications of different interpretations of static friction and its behavior under varying forces, which may lead to confusion in understanding the underlying physics principles.
boris16
hi
Is maximum possible static friction between a particular body and a particular surface equal or smaller to k(s) * N ?
k(s) means coefficient of static friction
If it is smaller, then only when force pulling on object is greater than C(s)*N will body start moving ?
I'm confused since I found few articles on the net saying max_possible_stat_fric < k(s) * N, while others even saying max_possible_stat_fric equals k(s) * N and yet at the same time claiming when both the pulling force and max_possible_stat_fric are equal to k(s) * N the object starts moving, which doesn't make sense since the two forces would cancel each other out
thanx
The force of static friction is less than or equal to (coefficient of s. friction)x(normal force). The maximim possible is equal to "k(s)*N" (as you put it.
The reason why static friction can be less, is due to the fact that if nothing is pushing on a stationary object, there is no frictional force at all on it. If a small applied force is put on the object, and the object does not move, then the static friction only has to be enough to balance the small applied force.
If an applied force that exactly equals the max static friction is on an object, technically forces are balanced and the object does not move; but if this applied force is infinitessimally larger, then the object will accelerate. Let's say the maximum static frictional force is 25 N. An object will begin to accelerate if you apply a force of 25.0000000001 N. This is why they say that the "minimum force required to start the motion is equal to the maximum static frictional force." Rounding to significant digits, 25.000000000001 equals 25.
thank you. It's strange tho that they wouldn't mention that since it can confuse a person
"They" do this all the time.
