How Does Bending Knees Reduce Impact Force During a Jump?
  • Thread starter Thread starter chipsdeluxe
    Theorem
The discussion focuses on the physics of landing techniques to reduce impact forces during a jump. A 66.9 kg man jumping at a speed of 4.22 m/s experiences significantly different average net forces depending on whether he lands stiff-legged or bends his knees. In a stiff-legged landing, the average net force is calculated to be approximately -68690.5 N over a time of 4.11 ms. When bending his knees, the average net force is determined over a longer time of 0.278 s, requiring consideration of both the upward force from the ground and the downward force of gravity.
  • Understanding of Newton's Second Law of Motion
  • Familiarity with impulse and momentum concepts
  • Basic knowledge of force calculations in physics
  • Ability to convert units of time from milliseconds to seconds
  • Study the relationship between impulse and momentum using the equations J = avgF * delta t and J = m(Vf - Vi)
  • Learn how to calculate average net force in different landing scenarios
  • Explore the effects of varying landing times on impact forces
  • Investigate the role of gravity in force calculations during jumps
This discussion is beneficial for physics students, sports scientists, and anyone interested in biomechanics, particularly those studying injury prevention techniques in athletic activities.
chipsdeluxe
When jumping straight down, you can be seriously injured if you land stiff-legged. One way to avoid injury is to bend your knees upon landing to reduce the force of the impact. A 66.9-kg man just before contact with the ground has a speed of 4.22 m/s. (a) In a stiff-legged landing he comes to a halt in 4.11 ms. Find the magnitude of the average net force that acts on him during this time. (b) When he bends his knees, he comes to a halt in 0.278 s. Find the magnitude of the average net force now. (c) During the landing, the force of the ground on the man points upward, while the force due to gravity points downward. The average net force acting on the man includes both of these forces. Taking into account the directions of the forces, find the magnitude of the force applied by the ground on the man in part (b).
Please help. this is how i solved the problem which is wrong:
a. Mman=66.9 kg
Vman=4.22 m/s
T=4.11 ms (1/1000)=0.00411 s
i used the equation:
F=-(m/t)v= -(66.9/0.00411)(4.22)=-68690.5 N
b. i used the same equation and only changed the time
c. i don't even know where to begin and i can't solve this until i get part a and b right.
thanks in advance
In these kind of questions you should use the fact that the impulse J equals:
J = avgF*delta t. and J also equals the change in momentum J = m(Vf-Vi)
with those two equations you should be able to solve it.
I'm not sure what equation you were using?
a. Mman=66.9 kg
Vman=4.22 m/s
thanks in advance
Your approach is correct.
The net force provides the acceleration:
[tex]F_{avg}=ma_{avg} = m\frac{\Delta v}{\Delta t}[/tex]
Your answer for a. appears to be correct.
But this is not the only force on the body. We are ignoring gravity which is acting (downward) at all times. But because it is balanced by the ground, it does not result in any downward acceleration. So the vector sum of all forces is:
[tex]m\vec g + \vec N = m\vec{a_{avg}}[/tex]
Solve for N.
AM
23K
