Need Confimation on Answer Process for Wheelbarrow Physics Question
  • Thread starter Thread starter ruzoo
    Physics Process
The problem involves calculating the effort required to lift a 100 kg load in a wheelbarrow, with the load's center of mass positioned at a specific distance from the axis and the handles held at a 30-degree angle from the ground. The discussion centers around the application of static equilibrium equations and torque considerations.
  • Participants discuss the use of static equilibrium equations and torque to determine the force required to lift the load. Questions arise regarding the angle used in calculations and the interpretation of torque relationships.
Some participants have offered different approaches to the problem, including the use of torque equations. There is an ongoing exploration of the angles involved and how they relate to the forces acting on the wheelbarrow.
Participants are navigating through the assumptions regarding angles and the application of forces, particularly in relation to the geometry of the wheelbarrow setup.
ruzoo
The questions is:
A wheelbarrow is used to carry a load of 100Kg. The load's centre of mass lies 1/3 of the way between the axis and the point where the handles are held (the distance between the axis and the handles is 1.5m), how much effort will be required to lift the load and hold it at an angle of 30 degrees from the ground?
This is what I did :
Used the equation of static equilibrium, where E = sigma, sum of
ETk = 0
ETk = (Fm sin 30)(df) - (wt)(dwt)
0 = (Fm sin30)(0.5m) - (980 N)(1.5m)
0 = Fmsin30 - 1470Nm
Fm = 5880 N
Is the method I took correct? Just looking for some insight...
Thanks
ruzoo said:
The questions is:
ETk = 0
Fm = 5880 N
No.
The equation for static equilibrium is:
[tex]\tau = 0[/tex]
There are two torques acting here, and they are equal and opposite:
[tex]M_{load}\vec g \times \vec{d_{load}} = \vec F_{hand}\times \vec{d_{hand}}[/tex]
where [itex]M_{load} =[/itex] 100 kg.; [itex]d_{load} = .5 m[/itex] and [itex]d_{hand} = 1.5 m[/itex]
So:
[tex]M_{load}gd_{load}sin(60)/d_{hand} = F_{hand}[/tex]
[tex]F_{hand} = 100 * 9.80 * .5 *.87 /1.5 = 284 N.[/tex]
This assumes that the force on the handles is always applied at right angles to the handles.
AM
I understand, sort of...where does the sin 60 come in? Where are you getting "60" from?
It is the cross-product:
[tex]M_{load}\vec g \times \vec d_{load} = M_{load}gd\sin(\theta)[/tex]
where [itex]\theta[/itex] is the angle of the force from the perpendicular to the line between the fulcrum and the point of application of the force. That angle is 60 degrees if the wheelbarrow is lifted 30 degrees from the horizontal.
AM
10K
